04/14/2008 12:08 PM
post6733
No biggy but line 1054 in pidin_proc.c (166123)
for (i = 0; args[i] && i < sizeof args / sizeof args[0]; i++) {
Should read
for (i = 0; i < sizeof args / sizeof args[0] && args[i]; i++) {
04/14/2008 12:21 PM
post6734
> Should read
Good catch. Thanks.
04/14/2008 12:34 PM
post6737
Care to explain for those of us who are missing the point? Namely, me. =)
Thanks and cheers,
-Brian
> From: Stephane Boucher [mailto:sboucher@qnx.com]
> Sent: Monday, April 14, 2008 12 22
> To: ostech-core_os
> Subject: Re: pidin
> args[0]; i++)
> > Should read
> args[i]; i++)
> Good catch. Thanks.
> http://community.qnx.com/sf/go/post6734
04/14/2008 12:38 PM
post6740
You want to make sure 'i' is valid before you use it to access the
array. There's a theoretical possibility that you might fault accessing
argv[i] if is beyond the end of the array.
> Thanks and cheers,
> -Brian
> > To: ostech-core_os
> > Subject: Re: pidin
> > args[0]; i++)
> > > Should read
> > args[i]; i++)
> > Good catch. Thanks.
> > OSTech
> http://community.qnx.com/sf/go/post6737
04/14/2008 12:55 PM
post6744
Ahh, thanks for clearing that up. It's very much appreciated.
Cheers,
-Brian
> Sent: Monday, April 14, 2008 12 38
> To: ostech-core_os
> Subject: RE: pidin
> Namely, me.
> fault accessing
> > Thanks and cheers,
> > -Brian
> > > To: ostech-core_os
> > > Subject: Re: pidin
> > > args[0]; i++)
> > > > Should read
> > > args[i]; i++)
> > > Good catch. Thanks.
> > > OSTech
> > OSTech
> http://community.qnx.com/sf/go/post6740
04/15/2008 8:12 PM
post6859
If you are going to check the bounds, you should probably not dereference it
before you do so. In this case the check doesn't matter since it is more of
an early out rather than a limit on the bounds, but you know ... things
happen.
Thomas
> > To: ostech-core_os
> > Subject: Re: pidin
> > args[0]; i++)
> > > Should read
> > args[i]; i++)
> > Good catch. Thanks.
> > OSTech
04/16/2008 9:21 AM
post6896
I seem to have lazily evaluated the lazy evaluation. =)
Thanks Thomas.
> From: Thomas Fletcher [mailto:tfletche@gmail.com]
> Sent: Tuesday, April 15, 2008 20 12
> To: ostech-core_os
> Subject: Re: pidin
> Namely, me. =)
> dereference it
> since it is more of
> ... things
> happen.
> Thomas
> > > To: ostech-core_os
> > > Subject: Re: pidin
> > > args[0]; i++)
> > > > Should read
> > > args[i]; i++)
> > > Good catch. Thanks.
> > > OSTech
> > OSTech
> http://community.qnx.com/sf/go/post6859
04/30/2008 2:25 PM
post7516
I would expect that lint can catch this but no?
04/30/2008 10:19 PM
post7538
pclint cought it.
Sent: Wednesday, April 30, 2008 2:26 PM
To: ostech-core_os
Subject: Re: RE: pidin
OSTech
http://community.qnx.com/sf/go/post7516
04/30/2008 10:37 PM
post7540
> pclint cought it.
> From: Yao Zhao [mailto:yzhao@qnx.com]
> To: ostech-core_os
that is it:)
but we do run lint on kernel source so maybe we turned some warning off:(
05/01/2008 8:06 AM
post7543
We run lint on services/system and lib/c
Sent: Wednesday, April 30, 2008 10:38 PM
To: ostech-core_os
Subject: Re: RE: RE: pidin
> pclint cought it.
> To: ostech-core_os
that is it:)
OSTech
http://community.qnx.com/sf/go/post7540
05/05/2008 12:48 PM
post7676
> From: Yao Zhao
> To: ostech-core_os
> > pclint cought it.
> > To: ostech-core_os
> > OSTech
> that is it:)
oh! it is pidin source, I miss that :)
