Forum Topic - error code 9 (EBADF) from posix_spawn:
During the first boot after cfp, the system is under incredibly heavy load due to lots of services performing setup at
the same time. During this period the launcher starts the cascades and webkit zygotes using posix_spawn. I've found
about 50% of the time the webkit spawn fails with
Jul 18 20:14:51    3    41   100 launcher: warning spawn_delegate:Could not spawn /bin/webkit-launcher launch delegate,
err=9(Bad file descriptor)
EBADF isn't a valid return code from posix_spawn according to the main page! (ENOENT is, but that's different...) What
could cause posix_spawn to return this?
Some differences I can think of between the webkit zygote and the cascades zygote, which hasn't reported this problem,
are:
webkit is last alphabetically so it is started later; since this error is intermittent, timing could be significant
/bin/webkit-launcher is a symlink to /usr/bin/weblauncher, so spawn is not trying to open the binary directly - could
EBADF be generated during a failure while trying to follow the symlink? (Note that by the time boot is finished and I
ssh in, both source and target of the symlink are in place and working fine.)
RE: error code 9 (EBADF) from posix_spawn
It could be that some file descriptors that were open in the parent process can't be duplicated into the child process.
(e.g. they were closed by the parent shortly after calling posix_spawn() )
Try spawnp() with fd_count 3 (fds 0, 1, 2) instead.
Re: RE: error code 9 (EBADF) from posix_spawn
Joe, did this fix your problem?  I am having a similar problem with spawn but it occurs less frequently than your
problem.  I made the suggested change but its difficult to test if this really fixes the problem.
