Forum Topic - Pulse and Partition: (3 Items)
Pulse and Partition
The Pulse will not carry partition info over, this is documented. However, I have real life situations like this.
The system have 2 partition, say System 70 and Media 30. All system services is run in System partition.
In Media, there is a low priority (4) thread want to read files, it talks to devb-eide in system partition. This brought
 a thread in devb-eide down to 4, but that's okay, becuse this thread is now belongs to Media partition.
The problem happens that sometime, the pri 4 devb-eide will sent a pulse to another thread in devb-eide, ans cond_wait()
 until the other thread finished it's work.
This "other thread" in devb-eide now set at pri 4, but belongs to "System" partition. So if other high priority thread
in System partition started to run, it will starve the devb-eide pri 4 thread. To make things worse, since Media
partition is not using CPU, the high priority thread in System partition would run 100%
Use a pulse to wake up another thread in server to do some more service is quite normal. This makes a partitioned system
 do not working as expected.
I have then tried to create a 3rd "common resource" partition, moved devb-eide into it. This make the starving harder to
 happen, but therotically, there is still someone else can talk to devb-eide in high priority, causing a high priroity
pulse being sent, and then starve the low priority thread...
Since "pulse" an carry priority (set by user), I think it is reasonable to allow user set "partitiion" in pulse and
carry it over.
Any thoughts on this in 6.4?
Re: Pulse and Partition
I can see the usefulness of specifying the cpu partition on a pulse send.
It would have to be an explicit paramater to send_pulse, like the current
priority paramater. That's because receiving a pulse does no inheritance
(priority inheritance or otherwise) from the sender.
However, it would become a security hole. Because nothing would prevent a
sender from specifying a partition that they were not a member of. So this
mechanism would effectively allow any thread to run in any partition
regardles of the APS security settings. So it would probably be unworkable,
unless we limited it's use to the root user.
We did think about it years ago and decided not to.
The biggest problem is that increasing the payload of the pulse, in order to
carry a partition field, may be a major kernel change and may even have
performace implications. So we would not undertake it lightly.
-ad
> talks to devb-eide in system partition. This brought a thread in
> to Media partition.
> to another thread in devb-eide, ans cond_wait() until the other thread
> finished it's work.
> "System" partition. So if other high priority thread in System partition
> things worse, since Media partition is not using CPU, the high priority
> is quite normal. This makes a partitioned system do not working as
expected.
> devb-eide into it. This make the starving harder to happen, but
> priority, causing a high priroity pulse being sent, and then starve the
> to allow user set "partitiion" in pulse and carry it over.
> http://community.qnx.com/sf/go/post6476
About the security, with a non-AP system, you can still fire high priority pulse to starve the server is it? So I would
argu with a patition inherit pulse in AP does not ADD more risk.
I understand it will be an impact to kernel, but just wonder if it is considered in the "next gen" kernel.
Anway, my case is, a CD ripping thread in "Multimedia" partition, starved a route caculation thread in "Navigation"
partition, despite the buddget I assign to different partitions. This defeats the purpose of using AP. Any suggestion in
 this situation?
