Forum Topic - Quiet version of the ipl-diskpc1: (4 Items)
I need version of the ipl-diskpc1 which doesn't print anything on the screen.
Where can I find source code of this bootloader ?
Jacek
Re: Quiet version of the ipl-diskpc1
Up. Same question.
Professors, help please.
generaly speaking your next question will be about ipl-diskpc2 ...
because the only thing, that the ipl-diskpc1 asks is the partition
to boot from:
    "Press F1-F4 to select drive or select partition"
At the offset 0x153 of the ipl-diskpc1 you would see the "0xCD 0x10"
- this is a BIOS call "Write Character in TTY Mode".
Just patch with NOP, NOP ( 0x90,0x90)
Or, you can just put a zero (0x00) at 0x166 in place of 0x50 ('P')
So, the text string "Press F1-F4 to select drive or select partition\0"
will be "\0ress F1-F4 to select drive or select partition\0".
No output. Mission complete.
The ipl-diskpc2 is a bit complicated. But also doable same way.
-- Alexandre
It works fine!!
Replacement of "0xCD 0x10" values at offset 0x153 with NOP, NOP did a trick.
We use a Power-Safe filesystem where the secondary bootloader can be tuned
with the use of mkqnx6fs utility:
   mkqnx6fs -B -O+quiet /dev/hd0t179
Thank you,
Jacek
