Re: The size field of resmgr_context_t
04/03/2008 3:07 PM
post6443
On Thu, Apr 03, 2008 at 02:47:32PM -0400, Steve Reid wrote:
> Getting Started with QNX Neutrino says this about the size field of
resmgr_context_t:
> (Note: there's a bug in the 2.00 release where this field does not get
stuffed in the case of a non-combine connect message. All other messages
operate correctly. The workaround in that case (and that case only) is to
use the info structure's msglen parameter.)
> Has this been fixed? Should I simply delete the above?
Yeah, it's been fixed.
Brian
