Forum Topic - support of shmget api:
I am trying to access the shared memory created in qnx using scripting language(perl).
But it throwing some error i.e. perl is returning saying this machine do not support shmget. Is there any way of
supporting it.
Re: support of shmget api
You can try running the s5ipc manager and linking perl against libs5ipc.
It's in pkgsrc under sysutils/s5ipc.
http://community.qnx.com/sf/projects/pkgsrc
supporting it.
> http://community.qnx.com/sf/go/post98631
Do you have a sample perl script?
Script is
#!/usr/bin/perl
 $file_shmem = "/home/Vishal_Home/bolts";
 $size_shmem = 18640;
  open( F, "./ftok $file_shmem 1 |" );
  $s1 = <F>;
  close F;
  chomp $s1;
  $ipckey = "0x$s1";
  print "IPC-KEY of ($file_shmem) is $ipckey \n";
  $idshm = shmget( $ipckey, $size_shmem, 0666  ) || die "\n Creation of shared memory failed $! \n";
  print "IPC-SHMEM: id $idshm \n";
  shmread( $idshm, $data_shmem, 0, $size_shmem )  || warn "\n\n Error reading shared-memory: $! \n";
Error is-
$ ./myshm.pl
IPC-KEY of (/home/Vishal_Home/bolts) is 0x
System V IPC is not implemented on this machine at ./myshm.pl line 10.
