Detecting HID devices in non-default configurations
09/04/2012 1:11 PM
post95365
I'm trying to write a client of the io-hid manager to support devices which only present a HID interface in a non-
default USB configuration. I was having a problem that io-hid didn't trigger insertions for the device, even when I used
an enum-usb script to place it in the correct USB configuration.
I've discovered a work-around which is to write an enum-devices script to re-mount devh-usb.so on io-hid, which seems to
trigger the correct insertion callback in my client code. However, this has the unwanted side-effect of causing all
existing HID devices to be removed and then re-inserted (only at the io-hid interface, not at the USB level). This
causes me problems since the devices are stateful and if I connect to them as if they were newly inserted then the
negotiation will fail.
Could anybody suggest a way to cause devh-usb.so to re-scan for new HID devices in a way which doesn't disconnect
already-connected ones?
It appears that whatever scan it does at startup detects devices with a HID interface in their current configuration,
but after this initial scan it only seems to be notified of new devices if they have a HID interface in their *default*
configuration. If I can find a way to trigger whatever scan it does at startup without causing removal notifications for
existing devices, I can trigger this from my enum-devices script and the problem will be solved.
Any ideas anyone could share would be very gratefully received.
