Forum Topic - QNX 6.5 OCB Extension Bug: (5 Items)
I would like to know if anyone tried and was succesfull extending OCB's on the 6.5 version. I believe that there is a
bug allocating the extended OCB memory. The code compiles and executes, however the RM is not accessible even thou it is
 listed under devices. On older versions of the OS the code works perfectly. If I comment the line where we overwrite
the mount.funcs structure (mount.funcs=&mount_funcs; in the attached code) the RM works but it may crash sometime since
the memory is not allocated corrected.  I am attaching the following code that shows the problem if anyone is interested
 in trying to fix it. It is a simple server/client application where the cliente registers its name on the server
extended OCB, and on every write() call the cliente sends the server prints the client name.
Anyone has any ideas how to work-around this bug?
Dante Tezza
ps: when running the client, the  desired name should be passed as an argument
Attachment: Compressed file ocbExtension.zip 2.87 KB
Re: QNX 6.5 OCB Extension Bug
Hi Dante,
have you found solution to this?
thanks,
Saul
Hi Saul,
I havent yet, I was solving another issue that we are facing but now I am getting back to solve this one. I will keep
the post updated.
Dante
Hi Dante,
I was interested in your post because we seem to have some similar issues in our application.
After working with your code for a while, I found a solution to your problem.  The problem with your code seems to be
where you call the iofunc_attr_init function.  When I run your original code, I get a core dump error after loading the
server and then running the client.  If I move the call to iofunc_attr_init down a few lines after the attr.mount
variable has been set, then the program works correctly.  I modified your code to accept a command line option.  If you
run the new code with option 1 (serverRM 1 &), it runs just like your original code.  If you run the new code with
option 2 (serverRM 2 &), then it calls the iofunc_attr_init function after the attr.mount variable has been set.
I can't explain why your code seemed to work on the older version of QNX.
I hope this helps.
-Tim Fisher
Attachment: Text OCBExtension.7z 2.4 KB
Hi Timothy,
Thanks for your help, I have been busy lately and didnt have much time to deal with this issue. I will read your code
and try it on our application and let you know how it goes.
Thank you,
Dante
