posix_spawnp diffifculties with file actions
08/01/2012 2:13 PM
post94571
I'm currently using posix_spawnp() to create child processes. I'm using posix_spawnp() instead of soawn() because I
need the ability to start the child process with a specified uid:gid that is not the same as the parent process. I also
want to "redirect" or open a specific file to rep[lace stdin, stdout, & stderr in the child process.
Anybody out there an 'expert' on posix_spawn ? The code below doesn't seem to work for the file replacement.
The following is a snipit of code [left out error handling] that I'm am using that is not working for the file portion.
The function is called simple_spawn(), parameters are the path/file of the process to spawn, and a pointer to a argv[]
type of array.
simpleSpawn( char *file, char **argv )
int rtn;
pid_t childPid = -1;
char * replFileName = "/var/log/mylog.txt";
posix_spawnattr_t spawnAttrib;
posix_spawn_file_actions_t spawnFileActions;
// init & setup attrib object
posix_spawnattr_init( &spawnAttrib );
posix_spawnattr_setxflags( &spawnAttrib, POSIX_SPAWN_SETCRED );
posix_spawnattr_setcred( &spawnAttrib, 0, 0 );
// init & setup file actions object
posix_spawn_file_actions_init( &spawnFileActions );
// replace stdin
posix_spawn_file_actions_addopen( &spawnFileActions, 0, replFileName, O_RDWR | O_CREAT | O_APPEND, 0600 )
// replace stdout
posix_spawn_file_actions_addopen( &spawnFileActions, 1, replFileName, O_RDWR | O_CREAT | O_APPEND, 0600 )
// replace stderr
posix_spawn_file_actions_addopen( &spawnFileActions, 2, replFileName, O_RDWR | O_CREAT | O_APPEND, 0600 )
// spawn the child
posix_spawnp( &childPid, file, &spawnFileActions, &spawnAttrib, argv, NULL )
return childPid;
