which & how to install compiler for ADA and Fortran? tried below stuff but stuck with errors >> g77: installation problem
06/05/2012 11:40 PM
post93535
This is for Fortran. Please advice for ADA too.
Got this error :- g77: installation problem, cannot exec `as': No such file or directory
when followed the below links and those files I installed
1] http://www.ajam.org.pl/
gcc4.6.1-x86-qnx6.5.0-bld1.tar.bz2
2] http://www.opal-rt.com/kb-article/how-compile-fortran-code-qnx-61-632-or-650
g77-rtp6.1-files-010921.tgz
3] http://hintsforums.macworld.com/archive/index.php/t-62445.html
searched for 'as' in /usr/qnx650/host/x86/usr/bin
and at that to PATH /usr/qnx650/host/x86/usr/bin
'as' is assembler but its missing there and also in root/usr/bin
# echo $PATH
/sbin:/usr/sbin:/bin:/usr/bin:/usr/photon/bin:/usr/photon/appbuilder:/opt/X11R6/
bin:/usr/X11R6/bin:/usr/local/bin:/opt/bin:/opt/sbin
# uname -a
QNX localhost 6.5.0 2010/07/09-14:43:25EDT x86pc x86
# qconfig
$QNX_CONFIGURATION not set, -d not given, and/or /etc/qnx/qconfig doesn't exist.
snaps and add.f file is in zip file attached
