Forum Topic - LIFO Scheduling of server threads: (5 Items)
The System Architecture guide explains that most of the time, threads are queued in FIFO order in the queue of their
priority, except for a server thread that's coming out of a RECEIVE-blocked state with a message from a client; the
server thread is inserted at the head of the queue for that priority -- that is, the order is LIFO, not FIFO.
(http://www.qnx.com/developers/docs/6.3.2/neutrino/sys_arch/kernel.html)
Does that mean that everytime a thread is receive blocked it is scheduled LIFO after receiving a message?
Can someone please explain in detail the conditions under which a thread is being scheduled LIFO?
Thomas
Re: LIFO Scheduling of server threads
> queued in FIFO order in the queue of their priority, except for a server
> client; the server thread is inserted at the head of the queue for that
> Thanks,
> Thomas
Priority matters.
There is a receive order.
Imagin:
A client thread c1 may have send a msg at prio
10 to server thread at some point in time.
Another client c2 send a msg with prio 11 later.
So far so good.
For some unknown reason the server has been busy with other work,
so once he enters the receive he should receive the msg "LIFO".
Hope this helps.
Jeevan
In your example two threads send messages with different prios to a server. The messages are queued and the order of
receiving them depends on their prio.
The way how I understand the System Architecture guide is that thread A, scheduling policy FIFO, prio n is busy and
doing some work. Meanwhile thread B, scheduling policy FIFO, prio n is receive blocked.
Now an interrupt comes in, delivering its message to thread B. Normally I would assume that thread B is inserted at the
end of the ready queue for prio n and thread A continue its work. When thread A is blocked again thread B begins its
work.
But regading the System Architecture guide thread B, coming out of the receive blocked state is inserted at the HEAD of
the ready queue and theirfore preempts thread A.
So that is what I understand of LIFO execution of threads.
Thomas
> server. The messages are queued and the order of receiving them depends on
> their prio.
> scheduling policy FIFO, prio n is busy and doing some work. Meanwhile thread
> would assume that thread B is inserted at the end of the ready queue for
> B begins its work.
Yes, in the case of an event coming from an interrupt handler (or
implicitely via InterruptAttachEvent()), then when B
transitions from RECEIVE --> READY it will be placed at the end of the queue
for priority 'n'.
> receive blocked state is inserted at the HEAD of the ready queue and
This is only true in the case where a client application is sending a
message to a server (via MsgSend()).  It is done
to more closely mimic the semantics of a monolithic kernel call where making
a call to a kernel service, does not
cause a scheduling operation.
Since servers generally inherit the priority of the sending thread (unless
the channel is explicitely created such that
the priority is not inherited) this isn't an issue.  The fact that you would
like you servers to use FIFO scheduling is
a bit different, but presumably your system design is doing that for a
reason.
Hope that this helps,
 Thomas
Yes, that helped. Especially to understand the conditions when this behaviour occurs.
The point is, I want both FIFO and LIFO scheduling respectively. I am able to control the behaviour by using either a
pulse or a complete message.
Normally I would only need a pulse (which has less communication overhead). Is there a chance to achieve the same LIFO
behaviour just by using a pulse?
Best regards,
Thomas
