Forum Topic - Restoring STDIN after redirection on command line ...: (6 Items)
A bit of a newbie question, possibly.
I am trying to have a QNX 650 built utility that normally accepts its input from stdin but can be run with a script file
 with "utility < scriptfile" and then revert to input from the keyboard when it hits EOF.
What is the best way to do this ??
Currently, at EOF I close "stdin" and then fopen("/dev/tty", "r") - this works well for the debug serial port but not
for telnet, etc.
TIA,
Bob
RE: Restoring STDIN after redirection on command line ...
Hi Bob,
I'm not sure if there is a really clean solution to your problem.
To achieve the desired behavior, you would need to:
- find out which device should become your new stdin
  (as you noticed, /dev/tty isn't necessarily the right choice), and
- redirect the stream 'stdin' to take its input from that device.
Finding the appropriate device may be anywhere between not too hard
and impossible. In the easy case, stdout or stderr refer to the TTY
you want to use. In the worst case, they have been redirected to
files or closed entirely, and your process has detached from its
controlling terminal (i.e., become a daemon) - in this scenario,
there'd be no reasonable guess which device to attach to.
Let's assume a simple case - stdout refers to a TTY.
You could of course just call  dup2( 1, 0 )  to duplicate the
stdout file descriptor and have the duplicate your current stdin
fd. The problem is that the (FILE) stream object represented by
*stdin will not be aware of this change. There is the  fdopen()
function to wrap a FILE object around an existing file descriptor,
but that will allocate a new object, not use an existing one...
...and alas, *stdin/-out/-err are static _objects_ - so we cannot
merely replace stdin by a new pointer.
You could try to flush and rewind the stdin stream, then
call  dup2( 1, 0 )  to replace the stdin file descriptor.
I'd suggest, though, to provide your input file via a command line
argument and have a few custom input functions that will read either
from that file or, once it reached EOF, the original stdin.
Cheers,
Thomas
From: Bob Selby [mailto:robert.selby@snellgroup.com]
Sent: Mittwoch, 2. Mai 2012 10:46
To: ostech-core_os
Subject: Restoring STDIN after redirection on command line ...
for telnet, etc.
TIA,
Bob
OSTech
http://community.qnx.com/sf/go/post92871
Thanks for that :-)
I tried the following for "util < scriptfile" and it seems to do what I
want ...
FILE * fc = stdin;
fgets(fc, ... // Reads from redirected script file
On EOF I do ...
fclose(fc);
fc = fdopen(STDOUT_FILENO, "r") ) == NULL )
fgets(fc, ... // Reads from keyboard
Bob Selby
Senior Engineer, Software
Snell
Innovation in the
Multi-Screen World
T +44 (0) 118 921 4592 (direct)
T +44 (0) 118 986 6123 (switchboard)
F +44 (0) 118 975 4920
snellgroup.com
Hartman House, Danehill, Lower Earley, Reading, Berkshire, RG6 4PB  UK
Routing | Modular Infrastructure | Conversion & Restoration | Live
Production | Automation & Media Management | Control & Monitoring
Sent: 02 May 2012 11:24
To: 'ostech-core_os@community.qnx.com'
Subject: RE: Restoring STDIN after redirection on command line ...
Hi Bob,
Finding the appropriate device may be anywhere between not too hard and
impossible. In the easy case, stdout or stderr refer to the TTY you want
to use. In the worst case, they have been redirected to files or closed
entirely, and your process has detached from its controlling terminal
(i.e., become a daemon) - in this scenario, there'd be no reasonable
You could of course just call  dup2( 1, 0 )  to duplicate the stdout
file descriptor and have the duplicate your current stdin fd. The
problem is that the (FILE) stream object represented by *stdin will not
be aware of this change. There is the  fdopen() function to wrap a FILE
object around an existing file descriptor, but that will allocate a new
...and alas, *stdin/-out/-err are static _objects_ - so we cannot merely
You could try to flush and rewind the stdin stream, then call  dup2( 1,
Cheers,
Thomas
To: ostech-core_os
input from stdin but can be run with a script file with "utility <
works well for the debug serial port but not for telnet, etc.
TIA,
Bob
OSTech
OSTech
http://community.qnx.com/sf/go/post92875
This email and any attachments are confidential, may be legally privileged and are intended for the use of the addressee
 only. If you are not the intended recipient, please note that any use, disclosure, printing or copying of...
Hi Bob,
that looks mostly reasonable. I'd still add a 'dup' or 'dup2',
though, to have separate file descriptors for stdin and stdout.
Cheers,
Thomas
From: Robert Selby [mailto:Robert.Selby@snellgroup.com]
Sent: Mittwoch, 2. Mai 2012 13:12
To: ostech-core_os@community.qnx.com
Thanks for that :-)
I tried the following for "util < scriptfile" and it seems to do what I want ...
FILE * fc = stdin;
fgets(fc, ... // Reads from redirected script file ...
On EOF I do ...
fclose(fc);
fc = fdopen(STDOUT_FILENO, "r") ) == NULL ) ...
Bob Selby
Snell
Innovation in the
Multi-Screen World
snellgroup.com
Routing | Modular Infrastructure | Conversion & Restoration | Live Production | Automation & Media Management | Control & Monitoring
Hi Bob,
Finding the appropriate device may be anywhere between not too hard and impossible. In the easy case, stdout or stderr refer to the TTY you want to use. In the worst case, they have been redirected to files or closed entirely, and your process has detached from its controlling terminal (i.e., become a daemon) - in this scenario, there'd be no reasonable guess which device to attach to.
You could of course just call  dup2( 1, 0 )  to duplicate the stdout file descriptor and have the duplicate your current stdin fd. The problem is that the (FILE) stream object represented by *stdin will not be aware of this change. There is the  fdopen() function to wrap a FILE object around an existing file descriptor, but that will allocate a new object, not use an existing one...
...and alas, *stdin/-out/-err are static _objects_ - so we cannot merely replace stdin by a new pointer.
I'd suggest, though, to provide your input file via a command line argument and have a few custom input functions that will read either from that file or, once it reached EOF, the original stdin.
Cheers,
Thomas
To: ostech-core_os
I am trying to have a QNX 650 built utility that normally accepts its input from stdin but can be run with a script file with "utility < scriptfile" and then revert to input from the keyboard when it hits EOF.
for telnet, etc.
TIA,
Bob
OSTech
To cancel your subscription to this discussion, please e-mail...
Very true ...
fc = fdopen(dup2(1, 0), "r");
seems to work OK too :-)
Thanks very much for the help :-)
Bob Selby
Snell
Innovation in the
Multi-Screen World
snellgroup.com
Sent: 02 May 2012 12:29
Hi Bob,
that looks mostly reasonable. I'd still add a 'dup' or 'dup2', though,
Cheers,
Thomas
Thanks for that :-)
want ...
FILE * fc = stdin;
On EOF I do ...
fclose(fc);
Bob Selby
Snell
Innovation in the
Multi-Screen World
snellgroup.com
Hi Bob,
Cheers,
Thomas
To: ostech-core_os
Subject: Restoring STDIN after redirection on...
Glad to help. :)
- Thomas
Sent: Mittwoch, 2. Mai 2012 13:34
Very true ...
Bob Selby
Snell
Innovation in the
Multi-Screen World
snellgroup.com
Hi Bob,
that looks mostly reasonable. I'd still add a 'dup' or 'dup2', though, to have separate file descriptors for stdin and stdout.
Cheers,
Thomas
Thanks for that :-)
FILE * fc = stdin;
On EOF I do ...
fclose(fc);
Bob Selby
Snell
Innovation in the
Multi-Screen World
snellgroup.com
& Monitoring
Hi Bob,
will read either from that file or, once it...
