RE: shm_ctl() fails when setting up a shared memory physical DMA
buffer for a PCI card
03/13/2012 9:19 AM
post92076
Hi Iain,
I can reproduce the problem - if the shared memory object already exists and has physical memory assigned to it.
When I run your code for the first time, it works perfectly. From then on, it will fail on shm_ctl. This kind of makes
sense, since you're trying to associate physical memory with a shared memory object which already has physical memory
associated with it. It's mostly the error code that is misleading.
Cheers,
Thomas
From: Iain Martin [mailto:community-noreply@qnx.com]
Sent: Dienstag, 13. März 2012 13:54
To: ostech-core_os
Subject: shm_ctl() fails when setting up a shared memory physical DMA buffer for a PCI card
I am trying to set up a shared memory buffer for DMA, so I can DMA directly in/out from one process and memcpy in/out
from other processes but shm_ctl() fails. I have been "doing the dance" with shm_open(), shm_ctl(), mmap() and
mem_offset64() but not managed to combine these in a way that enables the call to shm_ctl to succeed with the physical
flag set. There are other threads on this topic and I have followed their suggestions but they don't work for me. (for
example: http://www.openqnx.com/newsgroups/viewtopic.php?f=13&t=12398) The "tested example" that thread works for me but
it specifies the phyiscal address directly and does not obtain it from an mmap allocation followed by mem_offset64. As
soon as I pass the mmap allocation physical address to shm_ctl(), it fails with "error: Function not implemented".
I'm testing on a 4 core x86 PC.
An extract from my code is:
/* Allocate contiguous memory for DMA buffer */
/* byte size is page aligned */
uint32_t * ptr = mmap(NULL, bytesize, PROT_READ | PROT_WRITE | PROT_NOCACHE, MAP_PHYS | MAP_ANON, NOFD, 0);
/* Get the physical addresss, note that mem_offset fails so I use mem_offset64 */ mem_offset64(ptr, NOFD, bytesize, &
physical_addr_64, &contig_len
/* Create a shared memory object */
int fd = shm_open("/turnip", O_RDWR | O_CREAT, 0644);
/* Overlay the shared memory object to the physical memory address */ if (shm_ctl(fd, SHMCTL_GLOBAL|SHMCTL_PHYS,
physical_addr_64, bytesize) == -1) {
perror("shm_open");
exit(EXIT_FAILURE);
If I replace physical_addr_64 with 0xa0000, shm_ctl() works but this seems too risky because I am allocating a large
amount for memory for driver DMA buffers so I'm not happy just picking any physical address for a driver buffer.
If I just use mmap and memoffset_64 to have a DMA buffer in process memory space this works fine and if I create a
shared memory objects, this also works fine. I have read conflicting accounts of using ltruncate to allocate the
physical buffer but I couldn't get that to work either and Ithink I'm going round in circles now!
Any help or advice would be greatly appreciated. Is it possible to allocate a DMA buffer that can be shared between
processes?
OSTech
http://community.qnx.com/sf/go/post92072
