Forum Topic - QNX target can generate the executable file itself?: (5 Items)
I have a Winxp machne(Dual OS) with 1) 6.3.2 windows host IDE; 2) QNX 6.3.2 host. And another 6.3.2 target.
1. Can i generate the executable file run on the remote target in the IDE? Or i must build it on the 6.3.2 qnx host
machine.
2. How can i directly build the executable file on the target without dowloading it from the host machine? In other
words, what kind of componets i need to build into the image on the remote target so that the 6.3.2 target can generate
Re: QNX target can generate the executable file itself?
Or i must build it on the 6.3.2 qnx host machine.
yes, you can cross compile for your target from within the IDE on any
supported host.
dowloading it from the host machine? In other words, what kind of componets
If you have the Momentics 6.3.2 installed on the target, it is a self hosted
build. Doc on how to build is contained in the IDE as well as the forums and
wiki at qnx.com
OSTech
http://community.qnx.com/sf/go/post5510
<http://community.qnx.com/sf/go/post5510>;
> supported host.
> wiki at qnx.com
Hi, i think it not proper to install Momentics IDE on the target. Can i generate the excutable file for the target on
the Momentics on the Windows host instead? Thank u.
> generate the excutable file for the target on the Momentics on the Windows
That's what the Windows host is for.
You cannot generated it on the target, it must be build on the host machine and then copied onto the target
> dowloading it from the host machine? In other words, what kind of componets i
It's possible but very complicated, basically you need to setup the target just like a HOST, which may required an extra
 license...  Then you would need to use something like rcp to launch the build process remotely, ugly, very ugly.
Why would you need to do that?
