Forum Topic - syslogd not working:
syslogd not working
syslog is not working properly on 6.4.1
By default I have the following config file contents:
# cat /etc/syslog.conf
# The file must exist for logging to occur!!
mail.*                  /var/log/maillog
*.*                             /var/log/syslog
If I modify this in anyway, the logging doesn't work. If the log file path is modified, logs don't appear. If the config
 file doesn't exist, logs don't appear. If I add extra logging files, logs don't appear. If I add remote logging, logs
don't get exported over the net.
Any ideas?
Paul
Re: syslogd not working
Be careful of whitespace and line endings (no CRLF).
> *.*                             /var/log/syslog
config file doesn't exist, logs don't appear. If I add extra logging files, logs don't appear. If I add remote logging,
logs don't get exported over the net.
> Any ideas?
> Paul
> http://community.qnx.com/sf/go/post91012
This works:
"*.*                             /var/log/syslog"
This doesn't work
"*.*                             /var/log/sysLog"
I.e, a capatilization of the letter 'l'. There no write permissions issue. I can touch "/var/log/AnyThingIWant"
Make sure the file exists before syslogd is started.
On Thu, Jan 19, 2012 at 11:19:06AM -0500, Paul Boyle wrote:
> This works:
> This doesn't work
> http://community.qnx.com/sf/go/post91014
