Forum Topic - Timer expiry:
Timer expiry
We are creating timer through timer_create API using
       clock_id as CLOCK_REALTIME,
       event type as SIGEV_THREAD,
       and have registered some function for notification
We start this periodic timer with timeout value of 1 sec.
We have observed that most of times our function registered for notification is called after 1 sec. But sometimes our
function registered for notification is not called for several seconds (like 8-10 seconds).
What could be the reasons for this ?
Re: Timer expiry
I don't see why it would be 8-10 seconds but I don't work for QSSL so can't answer further on that. If the problem's on
your end my guess is you have a higher priority thread that runs READY every now and then for 8-10 seconds or an
interrupt handler that you don't return from for 8-10 seconds or a misbehaving interrupt handler that's attached to the
timer interrupt.
However, the Library Reference docs for sigevent under SIGEV_THREAD say "We don't recommend using this type of event.
Pulses are more efficient." Creating a thread is a bit heavy handed, especially for a repeating timer. I know your timer
 is 1 second but I don't know what your allowable error is.
So I'd suggest just changing your code to have an always running thread with an infinite loop that`s blocked waiting for
 a pulse and use SIGEV_PULSE instead or if portability is an issue then have the running thread blocked on sigwaitinfo()
 and use SIGEV_SIGNAL instead.
-Steven D.
RE: Timer expiry
Hello Aricent,
was this intended by you?
Bye,
 Christian
From: ext Steven Dufresne [mailto:community-noreply@qnx.com]
Sent: Tuesday, January 03, 2012 2:40 PM
To: ostech-core_os
Subject: Re: Timer expiry
can't answer further on that. If the problem's on your end my guess is
8-10 seconds or an interrupt handler that you don't return from for 8-10
seconds or a misbehaving interrupt handler that's attached to the timer
interrupt.
"We don't recommend using this type of event. Pulses are more
repeating timer. I know your timer is 1 second but I don't know what
with an infinite loop that`s blocked waiting for a pulse and use
thread blocked on sigwaitinfo() and use SIGEV_SIGNAL instead.
-Steven D.
OSTech
http://community.qnx.com/sf/go/post90789
AW: Timer expiry
Hi Christian,
Is your system time sometimes adjusted automatically? Try using CLOCK_MONOTONIC as the clock type.
Cheers,
Thomas
----- Originalnachricht -----
Von: Christian Scheuch [mailto:community-noreply@qnx.com]
Gesendet: Tuesday, January 03, 2012 05:32 AM
An: ostech-core_os <post90787@community.qnx.com>
Betreff: Timer expiry
OSTech
http://community.qnx.com/sf/go/post90787
RE: Timer expiry
Hello Aricent,
Bye,
 Christian
From: ext Thomas Haupt [mailto:community-noreply@qnx.com]
Sent: Tuesday, January 03, 2012 3:05 PM
To: ostech-core_os
Subject: AW: Timer expiry
Hi Christian,
Cheers,
Thomas
notification is called after 1 sec. But sometimes our function
seconds).
OSTech
OSTech
http://community.qnx.com/sf/go/post90793
Re: RE: Timer expiry
Thanks Steven. Thanks Thomas for the reply.
Yes our system time is updated but update is not quite often.
We will try the suggested alternatives.
We were suspecting low virtual memory as cause for this. How can we know that timer was expired but our function was not
 called because temporarily enough memory was not available to create the threads as after few seconds (8-10 seconds)
eventually our routine was called.
