02/25/2008 10:48 AM
post5235
On Mon, Feb 25, 2008 at 10:09:29AM -0500, Freddy Martens wrote:
> Can I lose pulses sent by another process?
No you won't.
> The documentation for MsgReceivePulse / MsgSendPulse states that an
> 8-bit count is kept in the kernel to count equal pulse messages.
> What happens if I send 1000 equal pulse messages to a process but I
> read them too slow with MsgReceivePulse? Do I lose pulse messages then?
The count is just to compress identical pulses to save on memory usage. If
the max is reached, another pulse entry is allocated and the process
repeats until max compression number is reached on that entry. If we
can't allocate a new pulse entry due to an out of memory condition, the
MsgSendPulse() call will fail with EAGAIN.
What we do have is a latency issue if the send queue for the channel
gets too long (e.g. too many unreceived pulses). Since the entries
in the send queue are inserted in priority order, we have to scan the
list for the right place to add the new entry. A long list means a
long scan. We hope to have that fixed in the 6.4 release.
