Forum Topic - dlopen fails and dlerr returns "No dynamic section ...": (9 Items)
I'm using dlopen within a process linked against static and shared libraries.
The dlopen call returns NULL is that case ... but the same shared lib works if dlopen is used within a process with
dynamic linking and without static linking.  The shared lib has a dynamic section as the attachment shows.
What's could be the problem ?   OS version 6.4.1 ...
--Armin
Attachment: Text dyn_sect.txt 9.89 KB
Re: dlopen fails and dlerr returns "No dynamic section ..."
same result with version 6.5 !
Attachment: Text .directory 2 KB
You are linking libc statically, and in that case dynamic linking won't
work.
> http://community.qnx.com/sf/go/post87732
> work.
   Not the case ... I'm linking against libs.so.3  ... dV is the
application:
# objdump -x dV | grep NEEDED
   NEEDED               libm.so.2
   NEEDED               libsocket.so.2
   NEEDED               libcpp.so.4
   NEEDED               libph.so.3
   NEEDED               libasound.so.2
   NEEDED               libSDL-1.2.so.0
   NEEDED               libc.so.3
--Armin
>> OSTech
> http://community.qnx.com/sf/go/post87756
Could you run your executable on 6.5.0:
# LD_DEBUG=1 ./dV
and see where is dlopen resolving from?
(Look for:
debug: Symbol dlopen bound to definition in ...)
>  > work.
> application:
> NEEDED libm.so.2
> NEEDED libcpp.so.4
> NEEDED libph.so.3
> NEEDED libc.so.3
> --Armin
>  >> OSTech
>  > OSTech
> http://community.qnx.com/sf/go/post87758
Aleksandar,
there are no debug outputs related to dlopen with the dV application
("dyn_debug.txt") ... but dlopen has been called ("dV-dlopen-call.c")
The trace file "working_libdll_test.txt" shows a working small test
program (same shared object, "libdll_test.c")
--Armin
> # LD_DEBUG=1 ./dV
> (Look for:
>>   >  work.
>> application:
>> NEEDED libm.so.2
>> NEEDED libcpp.so.4
>> NEEDED libph.so.3
>> NEEDED libc.so.3
>> --Armin
>>   >>  OSTech
>>   >  OSTech
>> OSTech
> http://community.qnx.com/sf/go/post87760
Attachment: Text dV-dlopen-call.c 210 bytes Text dyn_debug.txt 29.6 KB Text libdll_test.c 373 bytes Text working_libdll_test.txt 17.3 KB
I had no doubt that you do make a call to dlopen from your dV but the
question is what is it linked against? I still think you somehow managed
to link libc statically (at least dlopen definition).
Please do a 'nm' on your dV and see if dlopen is listed as an undefined
symbol. I would expect that it is either not listed (since it's
statically linked) or present and defined (which is not what you'd want
in an executable).
On 08/02/2011 11:29 AM, Armin Steinhoff wrote:
> Aleksandar,
> --Armin
>> # LD_DEBUG=1 ./dV
>> (Look for:
>>>    >   work.
>>> application:
>>> NEEDED libm.so.2
>>> NEEDED libcpp.so.4
>>> NEEDED libph.so.3
>>> NEEDED libc.so.3
>>> --Armin
>>>    >>   OSTech
>>>    >   OSTech
>>> OSTech
>> OSTech
> http://community.qnx.com/sf/go/post87768
Yes, that's the point!  The dlxxx calls are part of a static library.
But what the linker does seems a little bit unpedictable.
Using the -Bdynamic option shows that  "dlopen"  and "dlsym" are listed
as undefined in the output of "objdump".
"dlopen" and "dlsym" are working now but the execution of the code of
"dll.so" is crashing ...
However .... I will place the code for the dynamic linking stuff  into a
separate shared library and do linking
against libc.so.3 using the -Bdynamic option. Hope this helps ...
Many thanks for your help
--Armin
> in an executable).
>> Aleksandar,
>> --Armin
>>> # LD_DEBUG=1 ./dV
>>> (Look for:
>>>>     >    work.
>>>> application:
>>>> NEEDED libm.so.2
>>>> NEEDED libcpp.so.4
>>>> NEEDED libph.so.3
>>>> NEEDED libc.so.3
>>>> --Armin
>>>>     >>    OSTech
>>>>     >    OSTech
>>>> OSTech
Hi Aleksandar,
it's working now also for 6.4.1!!
The special -Bdynamic section must be closed with -lc ....
--Armin
--Armin
> in an executable).
>> Aleksandar,
>> --Armin
>>> # LD_DEBUG=1 ./dV
>>> (Look for:
>>>>     >    work.
>>>> application:
>>>> NEEDED libm.so.2
>>>> NEEDED libcpp.so.4
>>>> NEEDED libph.so.3
>>>> NEEDED libc.so.3
>>>> --Armin
>>>>     >>    OSTech
>>>>     >    OSTech
>>>> OSTech
