Forum Topic - Resource Manager Path Management: (3 Items)
My initial assumption was that you could only have one resource manager 'registered' at a particular point in the file
system.
Experience and closer reading of the docs suggests that it's possible to have more than one resource manager registered
to the same path.
I can see that this has uses but how do you ensure that you only create one instance of a driver? (assuming that there's
 potentially a race between different processes to create one)
There's no global mutex available so would you just design the system to avoid potential race conditions associated with
 driver creation?
RE: Resource Manager Path Management
Chris,
Unioned filesystems are a fundamental design of QNX Neutrino.  Take a
look at the rsrcdbmgr_* calls. Several resource managers use this API to
ensure only a single copy is running at a time.
David
> From: Chris Trobridge [mailto:community-noreply@qnx.com]
> Sent: July-25-11 10:24 AM
> To: ostech-core_os
> Subject: Resource Manager Path Management
manager
> 'registered' at a particular point in the file system.
> to have more than one resource manager registered to the same path.
create
> one instance of a driver? (assuming that there's potentially a race
> to avoid potential race conditions associated with driver creation?
> http://community.qnx.com/sf/go/post87571
Re: RE: Resource Manager Path Management
Thanks, this looks like it is just what I'm looking for.
Chris
