Forum Topic - return value from PPS file read() incorrect: (18 Items)
When I read() from a PPS file, I expect the number of bytes read to be returned.  However, I'm receiving the number of
bytes of the PPS file.  This is the case even when my buffer size is smaller than the PPS file.  This doesn't appear to
be following the standard POSIX read() behavior.
Re: return value from PPS file read() incorrect
Normally it works as you expect.  Can you post your code and the contents of the pps file?
Code:
int fd;
	int size_read;
	char buffer[8];
	/* Open a file for input */
	fd = open("/pps/ppsfile?wait", O_RDONLY | O_LARGEFILE, 0666);
	while (1) {
		size_read = read(fd, buffer, 5);
		printf("sizeread %d \n",size_read);
	/* Close the file */
	close(fd);
PPS file:
@ppsfile
attr::01234
Execution results:
sizeread 21
The pps object may contain multiple attributes, so it always returns the attribute name in front of "::".  You would
never get "01234" as you seem to be expecting.
For example...
@ppsfile
attr::01234
attr2::56789
Andy: you need to contact your official support channels and get an updated
pps server.
Btw, what is the output of use -i pps on your system?
> attribute name in front of "::".  You would never get "01234" as you seem to
> be expecting.
> For example...
> @ppsfile
> attr::01234
> attr2::56789
> http://community.qnx.com/sf/go/post86609
Here's the details (which Andy is testing with) for PPS:
# use -i pps
NAME=pps
DESCRIPTION=Persistent Publish Subscribe manager
DATE=2010/09/16-14:25:29-EDT
STATE=stable
HOST=mainbuild
USER=pspbuild
VERSION=650-2092
TAGID=3546
This is delivered with the BSP provided to us by QNX for our project.
Can Victor M. or Alain provide us with something newer that provides different results?
Glenn
For clarity, the correct result per the spec is to get -1 as the return
value from the call.
On my box your test program outputs:
sizeread -1
sizeread -1
sizeread -1
sizeread -1
sizeread -1
sizeread -1
My build is:
# use -i pps
NAME=pps
DATE=2011/05/27-14:20:13-EDT
STATE=internal
HOST=gusbuild5
USER=builder
VERSION=6.5.0
TAGID=1443
You likely have a priority support plan and this issue will get resolved
quickly if you raise a support ticket with your account manager.
> # use -i pps
> NAME=pps
> STATE=stable
> HOST=mainbuild
> USER=pspbuild
> VERSION=650-2092
> TAGID=3546
> results?
> Glenn
> http://community.qnx.com/sf/go/post86614
Default 6.5 has the bug described below, new one does not, but I don't think we have a patch for this publically
available.
> sizeread -1
> sizeread -1
> sizeread -1
> sizeread -1
> sizeread -1
> sizeread -1
> My build is:
> # use -i pps
> NAME=pps
> STATE=internal
> HOST=gusbuild5
> USER=builder
> VERSION=6.5.0
> TAGID=1443
>> # use -i pps
>> NAME=pps
>> STATE=stable
>> HOST=mainbuild
>> USER=pspbuild
>> VERSION=650-2092
>> TAGID=3546
>> results?
>> Glenn
>> OSTech
> http://community.qnx.com/sf/go/post86615
RE: return value from PPS file read() incorrect
That's true: HEAD has a lot of fixes and changes not in 6.5 (although the documentation hasn't caught up yet).
From: Elena Laskavaia [mailto:community-noreply@qnx.com]
Sent: Tue 2011-06-14 14:49
To: ostech-core_os
Subject: Re: return value from PPS file read() incorrect
available.
> sizeread -1
> sizeread -1
> sizeread -1
> sizeread -1
> sizeread -1
> sizeread -1
> My build is:
> # use -i pps
> NAME=pps
> STATE=internal
> HOST=gusbuild5
> USER=builder
> VERSION=6.5.0
> TAGID=1443
>> # use -i pps
>> NAME=pps
>> STATE=stable
>> HOST=mainbuild
>> USER=pspbuild
>> VERSION=650-2092
>> TAGID=3546
>> results?
>> Glenn
>> OSTech
OSTech
http://community.qnx.com/sf/go/post86618
Seems to be a poor practice for co-opting traditional POSIX read semantics for use with PPS. Seems like you'd be better
off providing a completely separate API instead of muddling with 'read' in this manner - in my opinion.
It would seem we have a bit of a Catch-22 situation here. If I don't know how large of a PPS buffer I may be reading, I
don't know how large a buffer I should be allocating for the read. Is there is some mechanism in PPS that will allow me
to determine the element size prior to the read? I don't want to pre-allocate a 64KB chunk of RAM just for reading an
arbitrary PPS item (assuming 64KB is the maximum size chunk returned by PPS).
Recommendations???
recommendation:
long_pps_size = pathconf(PPS_PATH, _PC_REC_MAX_XFER_SIZE );
> use with PPS. Seems like you'd be better off providing a completely separate
> large of a PPS buffer I may be reading, I don't know how large a buffer I
> allow me to determine the element size prior to the read? I don't want to
> pre-allocate a 64KB chunk of RAM just for reading an arbitrary PPS item
> Recommendations???
> http://community.qnx.com/sf/go/post86611
Which sounds like 64KB as documented in the PPS docs . . . yuck.
At least it's a system definition although my call to getconf on a QNX 6.5.0 command-line doesn't seem to recognize
_PC_REC_MAX_XFER_SIZE. Is this something new?
# getconf _PC_REC_MAX_XFER_SIZE /pps/hmiplayer/asResources
getconf: Can't find _PC_REC_MAX_XFER_SIZE
It should always have been there; whether the getconf command line utility knows it or not, I'm not certain (and can't
get at the source at the moment to check).
If you are certain that the object won't change while you are reading it, you can stat() it to get its current size.  If
 it can change, you have no choice but to assume worst case.  If you know a priori that the object in question has a
domain specific maximum size, you aren't obliged to use the PPS max, but that is always safest.
From: Glenn Schmottlach [mailto:community-noreply@qnx.com]
Sent: Tue 2011-06-14 15:55
To: ostech-core_os
OSTech
http://community.qnx.com/sf/go/post86620
The pathconf() function is different from the sysconf() function and the
getconf utility.
> command-line doesn't seem to recognize _PC_REC_MAX_XFER_SIZE. Is this
> something new?
I think in the release it will be fixed to return error in this case - because buffer cannot be smaller.
> http://community.qnx.com/sf/go/post86602
According to this from p23 of the document, the read() is supposed to FAIL.
"A read returns the length of the data read, in bytes. If the allocated read buffer is too
small for the data being read in, the read fails."
Seems to say partial, successive reads are not allowed.
This is true -- a PPS object isn't quite a "normal" file, and it has
some special semantics.  One of these is that reads must be complete --
you can't retrieve parts of a message in separate read calls.
What release are you referring to?
