Number of CPU cycles used by a thread
06/01/2011 7:36 AM
post86311
I cannot find from the documentation how to get the number of CPU cycles used by a specific thread during the last N
microseconds, or since the last time I enter a specific function.
How to to that programmatically with QNX?
I'm also searching how to get the idle time programmatically.
Thank you for any help,
Greg
Re: Number of CPU cycles used by a thread
06/01/2011 8:10 AM
post86314
Check out the ClockId() function (for use with ClockTime()). It will
give you the amount of time used by a particular thread. The value
returned is in nanoseconds, but the actually resolution is a timer
tick (default 1mS). The idle threads in the system are procnto tids
1 through N, where N is the number of cpus in the system, so
ClockTime(ClockId(1, 1), ....)
ClockTime(ClockId(1, 2), ....)
will give you the amount of idle time on each of the cpus.
On Wed, Jun 01, 2011 at 07:36:42AM -0400, Gregoire Banderet wrote:
> Hello,
> used by a specific thread during the last N microseconds, or since the
> Greg
> http://community.qnx.com/sf/go/post86311
10/19/2011 9:36 AM
post89450
Thnaks for the help.
ClockTime() works, but unfortunately I need a microsecond precision.
Is there another way to know programmatically how many CPU cycles my thread used during the last N microseconds?
Thank you,
Greg
10/19/2011 4:51 PM
post89463
Resolution of system clock is controlled by ClockPeriod() call.
I doubt you will be able to set/run resolution of 1 mks though. As per manual, the lowest clock period that can
currently be set on any machine is 10 microseconds.
10/20/2011 3:44 AM
post89472
Sure.
I'm looking for another way. Decreasing the clock period is not a solution, the CPU load will increase too much.
10/20/2011 4:05 AM
post89473
There simply is no another way. The kernel can't provide you with finer time resolution since it does not track it even
for itself.
10/20/2011 5:09 AM
post89474
It's the kernel job to schedule the execution of the threads. So I guess it knows which threads is running at any time.
When you use the system profiler in Momentics you see the execution of the threads, it's then easy to calculate the
number of microseconds of execution for a specific thread within a given time slot. I just need that programatically.
I'm currently porting some code written for INTime. INTime can reports the number of CPU cycles consumed by a thread
even with a clock period of 125us.
It will make me very sad if QNX couldn't do what INTime can :-)
-- Greg
RE: Number of CPU cycles used by a thread
10/20/2011 9:14 AM
post89479
Are you looking for something like the ClockCycles() API call in your program?
From: Gregoire Banderet [mailto:community-noreply@qnx.com]
Sent: Thursday, October 20, 2011 5:10 AM
To: ostech-core_os
Subject: Re: Number of CPU cycles used by a thread
-- Greg
OSTech
http://community.qnx.com/sf/go/post89474
10/20/2011 9:20 AM
post89481
How about the traceevent interrupt hook? Then you can know everytime a different thread is scheduled. I don't have the
api in front if me right now, so I probably have the function name wrong.
----- Original Message -----
From: Lichun Zhu [mailto:community-noreply@qnx.com]
Sent: Thursday, October 20, 2011 09:14 AM
To: ostech-core_os <post89479@community.qnx.com>
Subject: RE: Number of CPU cycles used by a thread
To: ostech-core_os
-- Greg
OSTech
OSTech
http://community.qnx.com/sf/go/post89479
Re: RE: Number of CPU cycles used by a thread
10/20/2011 9:31 AM
post89482
No. ClockCycles only reports the current CPU cycles counter value. The counter is global for all threads. I need one per
thread.
10/21/2011 12:32 PM
post89535
Gregoire : have similar problem in my project ..let me know if u get the answer ..
try this might be helpful
* The following program executes the program
* specified by argv[1]. After the child program
* is finished, the cpu statistics of the child are
* printed.
#include <stdio.h>
#include <stdlib.h>
#include <sys/types.h>
#include <sys/times.h>
int main( int argc, char **argv )
struct tms childtim;
system( argv[1] );
times( &childtim );
printf( "system time = %d\n", childtim.tms_cstime );
printf( "user time = %d\n", childtim.tms_cutime );
return EXIT_SUCCESS;
10/21/2011 3:16 PM
post89544
got something
http://www.qnx.com/developers/docs/6.3.0SP3/neutrino/utilities/s/sin.html
sin
Display system information:
threads (or th)
Show information about the threads of the displayed process. From the left, the columns show:
Tid -- Thread ID
Priority -- scheduling priority number and scheduling algorithm (see below)
State -- current state of the thread (see below for possible states)
Blocked -- the PID that this process is blocked on
IP -- the EIP register set used by the displayed process
CPU -- CPU occupancy time in milliseconds
try this ....
10/21/2011 3:23 PM
post89545
Also,
http://www.qnx.com/developers/docs/6.3.0SP3/neutrino/utilities/p/pidin.html
times
For each process displayed, show:
start time -- the time and date that the process was started
utime -- the number of CPU seconds consumed by the process
stime -- the number of CPU seconds has consumed on behalf of the process
cutime -- the number of CPU seconds consumed by the children of the process
cstime -- the number of CPU seconds has consumed on behalf of the children of the process
The times for the child processes are added to cutime and cstime only after the children terminate.
ttimes (or tt)
Show thread times.
Atul Kumbhar
10/22/2011 2:21 AM
post89553
Hi Gregoire,
I got code for pidin ...
10/22/2011 2:41 AM
post89554
Hi Gregoire,
here is sin...
10/22/2011 2:42 AM
post89555
Hi Gregoire,
here is sin...
let me know when u calculate the thread usage...
Atul Kumbhar
10/25/2011 6:23 PM
post89621
Thanks a lot for all these informations.
I will start to look at it in a few days.
Greg
On 10/22/2011 08:42, Atul Kumbhar wrote:
> Hi Gregoire,
> here is sin...
> Regards,
> Atul Kumbhar
> http://community.qnx.com/sf/go/post89555
Please be advised that this email may contain confidential
information. If you are not the intended recipient, please notify us
by email by replying to the sender and delete this message. The
sender disclaims that the content of this email constitutes an offer
to enter into, or the acceptance of, any agreement; provided that the
foregoing does not invalidate the binding effect of any digital or
other electronic reproduction of a manual signature that is included
in any attachment.
11/24/2011 6:08 AM
post90273
I eventually have some time to look into this...
I followed the QNX documentation under "Controlling processes via the /proc filesystem",
and I use open/devctl, DCMD_PROC_STATUS and the member procfs_status.sutime.
Unfortunately sutime increases by step of the cycle time value :-(
That means I cannot reach the granularity (1 microseconds) I need...
-- Greg
11/24/2011 9:24 AM
post90277
-- Greg
11/24/2011 1:10 PM
post90287
You can use system profiler, it will do a tracing with resolution of clockcycles, it has view that can aggregate data
per thread on selected region
On 11/24/2011 09:24 AM, Gregoire Banderet wrote:
> -- Greg
> http://community.qnx.com/sf/go/post90277
11/24/2011 10:55 PM
post90293
Hi ,
you can read post89302 by Elena Laskavaia it worked for me....
Thanks Elena Laskavaia Mam .. :)
Atul Kumbhar
> clockcycles, it has view that can aggregate data per thread on selected region
> > Hi,
> filesystem",
> > -- Greg
> > OSTech
11/25/2011 2:35 AM
post90295
I'm not profiling my QNX executable. I'm implementing a feature for a client. The timings values are then reported to a
Windows IDE through TCP/IP.
The QNX executable is a multi-threaded virtual machine running the customer's PLC application. Our customers want to do
some profiling of their application executed by the Virtual machine running on QNX.
That means I need timings values of a granularity of 1 microseconds and this profiling feature must not increase the CPU
load (1 or 2 percent of CPU power is acceptable).
The system profiler is not available in customer site.
Is there any way to use the tracing API in order to gather threads data? Is there events for the start and end of
execution for every threads?
-- Greg
> -----Message d'origine-----
> De : Elena Laskavaia [mailto:community-noreply@qnx.com]
> Envoyé : Thursday, November 24, 2011 19:11
> À : ostech-core_os
> Objet : Re: Number of CPU cycles used by a thread
> > Hi,
> > /proc filesystem", and I use open/devctl, DCMD_PROC_STATUS and the
> > -- Greg
> > OSTech
> http://community.qnx.com/sf/go/post90287
in any attachment.
11/25/2011 11:52 AM
post90303
If you customer running instrumented kernel you can hook in to tracelogger API. You would need to enable events on when
thread start/stop running and start tracelogging from the code of your utility, then run custom "traceprinter" to
aggregate the data
On 11/25/2011 02:35 AM, Gregoire Banderet wrote:
a Windows IDE through TCP/IP.
do some profiling of their application executed by the Virtual machine running on QNX.
CPU load (1 or 2 percent of CPU power is acceptable).
> -- Greg
>> À : ostech-core_os
>>> Hi,
>>> -- Greg
>>> OSTech
>> OSTech
> in any attachment.
> http://community.qnx.com/sf/go/post90295
11/25/2011 11:56 AM
post90304
Please note that trying to take accurate timing measurements in a VM is
not going to work very well!
when thread start/stop running and start tracelogging from the code of your utility, then run custom "traceprinter" to
aggregate the data
>> Hi,
>> -- Greg
>>> À : ostech-core_os
>>>> Hi,
>>>> -- Greg
>>>> OSTech
>>> OSTech
>> in any attachment.
>> OSTech
> http://community.qnx.com/sf/go/post90303
cburgess@qnx.com
11/28/2011 3:06 AM
post90309
The VM takes the measurements, not a program running inside the VM.
Every 250us the VM executes a program and I would like to know how many CPU cycles were used for the execution of this
program.
The VM is really not an issue, I talked about it to explain the situation at customer's site.
I'll look at TraceEvent API.
-- Greg
> De : Colin Burgess [mailto:community-noreply@qnx.com]
> Envoyé : Friday, November 25, 2011 17:57
> À : ostech-core_os
> Please note that trying to take accurate timing measurements in a VM is not
> > tracelogger API. You would need to enable events on when thread
> > utility, then run custom "traceprinter" to aggregate the data
> >> Hi,
> client. The timings values are then reported to a Windows IDE through
> TCP/IP.
> customer's PLC application. Our customers want to do some profiling of their
> this profiling feature must not increase the CPU load (1 or 2 percent of CPU
> there events for the start and end of execution for every threads?
> >> -- Greg
> >>> Envoyé : Thursday, November 24, 2011 19:11 À : ostech-core_os Objet
> >>> selected region
> >>>> Hi,
> >>>> the /proc filesystem", and I use open/devctl, DCMD_PROC_STATUS
> and
> >>>> the
> >>>> -- Greg
> >>>> OSTech
> >>> OSTech
> >> by email by...
