02/12/2008 3:31 PM
post4970
There is a shared memory object (NVRAM, ~24Mbytes) on my target board. I tried to map a block of NVRAM memory as my DMA
buffer as below,
fd = shm_open(shm_buff_name, O_RDWR, 0);
vaddr = mmap(NULL, 0x20000, PROT_READ | PROT_WRITE | PROT_NOCACHE, MAP_SHARED, fd, shm_buff_off);
mem_offset64(vaddr, NOFD, 0x20000, &paddr, NULL);
The 'shm_buff_off' is the offset inside the NVRAM, where I want to allocate memory from.
When ‘shm_buff_off’ was changed, for example, from 0x100000 to 0x200000, the ‘vaddr’ was changed accordingly.
However, the ‘paddr’ was always same. What is possible reason?
02/13/2008 8:54 AM
post4998
> to map a block of NVRAM memory as my DMA buffer as below,
> memory from.
> ‘vaddr’ was changed accordingly. However, the ‘paddr’ was always same.
Is it possible you got them reversed, because it's more likely vaddr wouldn't have changed, it's a virtual address.
> Thanks,
02/13/2008 2:45 PM
post5007
I tested it again. I found that both of vaddr and paddr are same for different offset. Below is my test code,
vaddr = mmap(NULL, 0x20000, PROT_READ|PROT_WRITE|PROT_NOCACHE, MAP_SHARED, fd, shm_buff_off);
if (vaddr != MAP_FAILED) {
int config_len;
if (mem_offset64(vaddr, NOFD, 0x20000, &paddr, &config_len) != -1) {
printf("Memory available 0x%x, vaddr 0x%x, paddr 0x%x ", config_len, (uint32_t)vaddr, paddr);
Moreover, the 'config_len' is always 0x1000. I am not sure if it is correct. However, the allocated DMA buffer works
fine.
02/13/2008 3:19 PM
post5011
What version of the OS are you using? There's PR 28536 if you're using
6.3.0 or earlier - if you were using shm_ctl(...,SHM_CTL_PHYS,...), the
mmap()
didn't add the offset parm to the base address of the object properly.
The bug got fixed in 6.3.2.
02/14/2008 9:33 AM
post5029
Thanks a lot. The OS version is 6.3.0.
