01/28/2011 9:41 AM
post82724
On Fri, 2011-01-28 at 09:10 -0500, Mario Charest wrote:
> Any way I can confirm this?
I would ask in the IDE forum, I would expect that IDE can give you some
convenient way (memory analysis, librcheck and stuff)
01/28/2011 9:46 AM
post82728
Call mmap(NULL, 15*1024*1024, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANON | MAP_LAZY, NOFD, 0), if it fails, it means
that you can not get any virtual memory larger than 15M.
Jerry Sui | Software Developer | jsui@qnx.com
O:613-591-0836 x 2904 C:613-240-9239 | www.qnx.com | QNX Software Systems
Cisco Support Team email: cisco_support@qnx.com
Sent: January 28, 2011 9:10 AM
To: ostech-core_os
Subject: RE: weird malloc failure
> -----Message d'origine-----
> De : Aleksandar Ristovski [mailto:community-noreply@qnx.com]
> Envoyé : 28 janvier 2011 08:56
> À : ostech-core_os
> Objet : Re: weird malloc failure
> It may be that your virtual address space gets too fragmented?
Yes that`s possible our code does a lot of realloc, which I`m in the process of getting rid of.. Any way I can confirm
this?
> I don't think that the fact that you start process with on -P matters, our
> malloc will only work within first 4G of virt. address space.
> Aleksandar
> On Thu, 2011-01-27 at 18:49 -0500, Mario Charest wrote:
> > I have a program ( x86 ) that will return null for malloc of 15 meg.
> > Juste before the malloc I print some heap stats, it's 80Meg is size
> > of wich 2 Meg is unused. There is 16 Gig of ram in the machine of
> > which 8G is free ( and the program is started with on -P ).
> > It takes a while of this to happen and before the failure there has
> > been over 800 call to that same malloc that worked fine.
> > Why would malloc failed? I'm suspecting memory corruption, would that
> > explain it? If check the rlimits, there ok. Can the memory manager
> > return null for some "undocumented" reasons?
> > OSTech
> > http://community.qnx.com/sf/go/post82703
> http://community.qnx.com/sf/go/post82712
OSTech
http://community.qnx.com/sf/go/post82716
