Forum Topic - Looking for default value of RLIMIT_NOFILE :
Howdy,
1. Can anyone provide me the default value of RLIMIT_NOFILE?
2. How does RLIMIT_NOFILE work with the -F option to procnto?  e.g. If I use procnto -F, does this update RLIMIT_NOFILE?
http://www.qnx.com/developers/docs/6.4.1/neutrino/user_guide/limits.html
Based on the QNX 6.4.1 documentation (limits, see link above), this soft value "may" constrain the total file
descriptors available.  I don't know exactly what that means.
Cheers,
maurice
Re: Looking for default value of RLIMIT_NOFILE
By default procnto sets a system-wide default of 1000 per process you
can use -F to specify a different default.
In your 6.4.1 system, RLIMIT_NOFILE is defined as 5 (#include
<sys/resource.h>). In either case if you want to modify the limit for
the current process and any that it creates you use setrlimit().
Sorry to properly answer your question the default value of
RLIMIT_NOFILE is 1000 which is set by procnto.
