Re: >3Gb userspace VM on x86 QNX
01/03/2008 10:00 AM
post4033
I'm not absolutely positive why it's screwing up, but I'm pretty sure
it's because the code that sets up the 1-to-1 region is designed to
have it done with big pages (2/4MB). With you moving it by 4K, you can't
use the big page mappings and I'm guessing that's messing something
up (e.g. not allocating all the level 2 (page table) entries needed).
The 1-to-1 region isn't required on X86's (we don't have it on chips
that don't support the Page Size Extension), so my suggestion would be
to just delete it entirely if you're trying to shrink the system vaddr
space. The easiest way of doing that it just to make sure that the
X86_CPU_PSE bit doesn't get turned on by the init_one_cpuinfo() function
in startup.
Brian
On Wed, Jan 02, 2008 at 12:22:37PM -0500, James Mulcahy wrote:
> Hello,
> I've an application which requires >3Gb of VM space and I'd like to try
and compress down the 1Gb of VM which the QNX kernel reserves such that my
application will run. Reducing its VM requirements in this instance is not
an option, so I'd really like a solution to this if possible.
> I can see from system/memmgr/x86/cpu_mm_internal.h that the
CPU_USER_VADDR_END address defaults to 0xbfffffffu. I've experimented with
moving this up further and had some success, along with success in moving
the L2MAP_BASE, PROCMEM_BASE and also success in compressing some of these
regions down in size (MAP_SIZE to 64Mb from 128Mb, and L2MAP_SIZE (though
this #define doesn't exist in its own right) down to 4Mb and both work fine
for me).
> What I'm really stuck on is moving the 1-TO-1 Virtual->Physical region.
I've found the code in startup-bios which matches that in
x86/cpu_mm_internal.h, specifically:
> hardware/startup/lib/x86/x86_mmu_4m.c
> #define RAM_VADDR 0xe0000000
> #define RAM_MAP_SIZE 0x10000000
> and system/memmgr/x86/cpu_mm_internal.h
> #define CPU_SYSTEM_PADDR_START 0
> #define CPU_SYSTEM_PADDR_END ((256*1024*1024)-1)
> #define CPU_1TO1_VADDR_BIAS 0xe0000000u
> I've succeeded in booting a kernel which has this region shrunk from 256Mb
to 128Mb, but what I cannot get working is a world in which this region is
moved to any address other than 0xe0000000. Even if I move it off by a
single page, QNX hangs during bootup.
> I've littered the code with kprintf's and tracked the hang down to a
nano_alloc() call, specifically this section of code:
> if((size -= new_size)) {
> add = PTRADD(new,
new_size);
> add->size = size;
> I have printouts each side of the add->size write, but I never see any
printouts following this write. &(add->size) in this case is 0xe80000c4,
which is curiously inside the last page in the 1-TO-1 region in my world
(where I've moved the 1-TO-1 region to 0xe0001000). At first I thought this
was the issue, but looking at a stock world which hasn't been moved off by a
page, the address of add->size is also a page earlier, at 0xe7fff0c4 (again,
the last page of the 1-TO-1 region).
> I've grepped around for other references to this address, in case I'd
missed anywhere it was also hard coded, but I've not found any.
> Does anyone understand why I'm having difficulty moving this region or can
you suggest how best to attack this problem going forward?
> http://community.qnx.com/sf/go/post4021
+1 (613) 591-3579 (fax) Kanata, Ontario,...
