QNX 6.4.1 Freezing on Single Board Computer
06/01/2010 11:31 AM
post55878
I'm running QNX on a WAFER-945GSE2 Single Board Computer, and previously ran 6.3.0 SP3 with the full Photon installation
with no problems. However, due to an issue with network drivers I had to update to 6.4.1 and this is where I'm running
into trouble.
When the system starts, it boots fine, until I hit the "Screen resolution Change" - the initial Photon window for
setting screen size. Now, the system runs for about 10 seconds before freezing. At first I thought that just the mouse
stopped working, but as I was able to quickly hit "apply", it changed resolution, showed the "do you want these settings
" popup, then froze: the timer stopped. So, I've unplugged the drive, and using my development PC, I disabled Photon
under "Global Options". After logging in commandpromt (or before, depending on delay), the system freezes after
proximatly 10 seconds. What can be the casue of this?
