Forum Topic - Can not start HAM in boot script : (3 Items)
Hi all,
I can not start HAM in boot script.
However, when system booted, I type ham in console and it run OK.
Here is my ham related command in boot script.
ham -vvvvvv
waitfor /dev/ham 4
Below is the verbose info when I use "ham -vvvvvv" in boot script.
0.000000000s: Ham: Started: (1456000000)
0.075000000s: Ham: Log timestamp started:1970/01/01 00:00:01:530000000
0.161000000s: Ham: No such file or directory:could not spawn guardian
I try placing the "ham -vvvvvv" command in different position in boot script (even the last line). But it can not start.
I use Momentics6.4.1 on ARM9.
Do you have any ideas?
Tiger
Re: Can not start HAM in boot script
Can you set the PATH variable and then spawn HAM
so as
	PATH=/proc/boot ham -vvvvvv
	waitfor /dev/ham 4
(or include the directory whereever ham is located, into the PATH
variable).
thanks
shiv
Mon May 24 20:26:19 EDT 2010
 --> According to Hu Chen <--
	Hi all,
	ham -vvvvvv
	waitfor /dev/ham 4
	Tiger
	OSTech
	http://community.qnx.com/sf/go/post55427
Shiv Nagarajan,
Kernel Developer, QNX Software Systems,
Ottawa, Canada
Got it done!
Thanks!
