Forum Topic - missing const qualifiers in scandir() declaration in <dirent.h>: (2 Items)
Dear all,
I have found, that header <dirent.h> contains scandir() declaration without const qualifier for the first argument.
extern int      scandir(char *__dirname, struct dirent ***__namelist,
                        int (*__select)(const struct dirent *),
                        int (*__compar)(const void *,const void *));
According to POSIX:2008 standard (http://www.opengroup.org/onlinepubs/9699919799/functions/scandir.html, I do not know
how about the others) there should be const qualifier for the first argument.
In fact, the QNX libc source code (lib/c/unix/scandir.c) declares const for all the parameters.
I have found this issue while porting some C++ code to QNX, because of call:
scandir(string.c_str(), ...);
Of course I can do a cast to (char *), but it is not nice solution.
Do you think that this can be somehow solved in QNX headers?
Best regards,
Re: missing const qualifiers in scandir() declaration in <dirent.h>
scandir() was only introduced with version 7 (i.e. 2008) and we are
currently certified against earlier versions (most recently, I think,
PSE52 2003).  Prior to this, it is supported as a miscellaneous Unix
extension.
I've raised PR76860 for this issue.  I can't say with any certainty how
or when this will be addressed as it may get tangled up in the broader
issue of 2008 compliance. Apologies for the inconvenience.
Keep in mind that "char * const" does not mean the same thing as "const
char *" :-)
Neil
