05/10/2010 11:24 AM
post54067
Is there a way to know in advance capacity of ClockCycles() counter?
I.e. is it really 32bit or 64? I.e. in how many seconds it is going to wrap around?
Re: ClockCycles() wrapping
05/10/2010 12:07 PM
post54072
0xffffffffffffffffull / SYSPAGE_ENTRY(qtime)->cycles_per_sec
will give you the number of seconds before wrapping.
> http://community.qnx.com/sf/go/post54067
05/10/2010 12:09 PM
post54073
CLOCKCYCLES_INCR_BIT is defined in <cpu>/neutrino.h to be the amount
that the raw counter
is shifted up.
cburgess@qnx.com
05/10/2010 1:34 PM
post54086
I guess I was not clear, but I understand now - it always wrap at 0xffffffff, but if actual counter
is at lower resolution kernel "upconverts" it using CLOCKCYCLES_INCR_BIT .
In general I would like to make a function that prints a time relative to "timeZero"
i.e.
uint64_t cycles = ClockCycles() - timeZero;
But it cannot be negative (because it is unsigned), so I need to do some tricks to
make this expression correct. I am not that good a C if somebody knows easy way to do
it let me know.
Two more problems:
1) ClockCycles on multicore
Apparently ClockCycles() is not synchronized between CPU's. Which makes profiling bogus,
i..e
start = ClockCycles(); // on cpu0
stop = ClockCycles(); // on cpu1
stop - start = garbage
How do I deal with that?
a) Can I ask for ClockCycles() from the same cpu always, not the current one?
b) Can I sync them programmatically?
c) Can I sync them on startup on target some how?
2) On some CPU's ClockCycles is inline function, and when I compile app with --instrument-functions it instruments it! I
have re-entry prevention but it still sucks because it is
a lot of overhead. I tried to add another declaration of ClockCycles with __attribute__ ((no_instrument_function)) but
it does not help - it has to be in original declaration I guess.
Any other suggestion (besides fixing the header)?
RE: ClockCycles() wrapping
05/10/2010 2:00 PM
post54092
> Sent: May 10, 2010 1:34 PM
> To: ostech-core_os
> Subject: Re: ClockCycles() wrapping
> wrap at 0xffffffff, but if actual counter is at lower
> i.e.
> need to do some tricks to make this expression correct. I am
> not that good a C if somebody knows easy way to do it let me know.
How do you determine timeZero? Is it an earlier call to ClockCycles()?
Ignoring the SMP case, ClockCycles() will always return a >= number than
a previous call to ClockCycles().
> Two more problems:
> Which makes profiling bogus, i..e
> the current one?
Other than binding the instrumented code to a fixed CPU? I don't' know.
> have re-entry prevention but it still sucks because it is a
Is it enough to change services/system/public/<cpu>/neutrino.h and add
the __attribute__ (no_instrument_function)? For at least ARM, the
function body is actually in an asm file in
lib/c/kercover/arm/ClockCycles.S
> http://community.qnx.com/sf/go/post54086
05/10/2010 2:44 PM
post54096
Well, at least until it wraps around ;-)
> > the current one?
There is no generic way to sync between processors. (They may not even
be running at the same rate....)
Instrumentation would only apply to inline C code, so pure assembly
wouldn't be a problem, C declaration notwithstanding. The attribute
should have done the trick, provided it appeared before the definition
was encountered by the compiler. (The simplest way to arrange for this
is, of course, to change the header -- which is almost certainly what
ought to be done.)
05/10/2010 2:49 PM
post54098
> From: Neil Schellenberger [mailto:community-noreply@qnx.com]
> Sent: May 10, 2010 2:44 PM
> To: ostech-core_os
> Subject: RE: ClockCycles() wrapping
> need to do
> > > some tricks to make this expression correct. I am not
> that good a C
> ClockCycles()?
> > than a previous call to ClockCycles().
Yes, I kinda flunked kindergarten 101 with that comment. So then the
question becomes "how can an application determine how many times
ClockCycles() has wrapped?"
> > > current one?
> don't' know.
> may not even be running at the same rate....)
> I compile
> > > app with --instrument-functions it instruments it! I have
> re-entry
> > > prevention but it still sucks because it is a lot of overhead. I
> __attribute__
> > > ((no_instrument_function)) but it does not help - it has to be in
> assembly wouldn't be a problem, C declaration
> notwithstanding. The attribute should have done the trick,
> provided it appeared before the definition was encountered by
> the compiler. (The simplest way to arrange for this is, of
> what ought to be done.)
> http://community.qnx.com/sf/go/post54096
05/10/2010 2:54 PM
post54099
You can't, but
diff = ClockCyles() - start_cycles;
will produce the right answer as long as you haven't exceeded a
cycle count of 0xffffffffffffffffULL. Making that work is why we scale
up the value when the hardware doesn't provide a full 64 bit counter.
05/10/2010 3:23 PM
post54103
> From: David Sarrazin [mailto:community-noreply@qnx.com]
> Sent: Monday, May 10, 2010 2:50 PM
> To: ostech-core_os
> > To: ostech-core_os
> > need to do
> > that good a C
> > ClockCycles()?
Given a 4G clock, the low 32 bit will wrapped after 1 seconds, that means the 32 upper bit are the number of seconds the
value can represent and it`s a VERY long time ;-) Something like 120 years.
> > > > current one?
> > don't' know.
> > I compile
> > re-entry
> > __attribute__
> > OSTech
> http://community.qnx.com/sf/go/post54098
05/10/2010 3:30 PM
post54105
the value can represent and it`s a VERY long time ;-) Something like 120 years.
3 minutes on MIPS
05/10/2010 4:43 PM
post54112
> Sent: Monday, May 10, 2010 3:31 PM
> To: ostech-core_os
> means the 32 upper bit are the number of seconds the value can
> 3 minutes on MIPS
Huh? How can that be?
> http://community.qnx.com/sf/go/post54105
05/10/2010 4:49 PM
post54118
> > To: ostech-core_os
> > 3 minutes on MIPS
We only use a 32 bit counter on MIPS :-)
05/10/2010 3:01 PM
post54100
to summarize
0)
does produce right answer. I think I got wrong one because I was doing something like
shift = CLOCKCYCLES_INCR_BIT;
diff = (ClockCyles() >> shift) - (start_cycles >> shift);
1) For synchronization:
there is no way to sync ClockCycles on multi core I need to keeps all
cpu ClockCycles offsets, not just one
now I need to figure our how to get ClockCycles for all cpus...
2) For no instrument functions I need to include my declaration before
header file or send pr to os/lib to fix the header
