Forum Topic - io_notify:
io_notify
I'm having a resource manager client waiting for an event using select.
The resource manager has the following routine:
int io_notify(resmgr_context_t *ctp, io_notify_t *msg, RESMGR_OCB_T *ocb)
  static bool first_time = true;
  int trig;
  trig = _NOTIFY_COND_OUTPUT;
   if ( first_time )
     trig |= _NOTIFY_COND_INPUT;
    first_time = false;
   return (iofunc_notify(ctp, msg, ((PExAttrib)ocb)->notify, trig, NULL, NULL));
I notice that the event gets delivered to the client when connecting for the first time This is what I expected since
the trigger  _NOTIFY_COND_INPUT is set the first time.
However calling the iofunc_notify_trigger routine doesn't do anything. I call this routine whenever I write to the
resource manager to inform the client that new data is available. the call looks like this:
iofunc_notify_trigger(((PExAttrib)ocb)->notify, 1, IOFUNC_NOTIFY_INPUT);
I notice that the notify structure has an empty list and a bogus cnt value:
   notify[0] : cnt=2147483647
                    list=0x00000000
what can be the reason for this. It looks as if the notify structure is not correctly setup by the iofunc_notify routine
