Re: Redirecing virtual console output (devc-ditto)
04/20/2010 5:08 AM
post52094
Try to put "sleep 1" between devc-ditto command and reopen in your script file
PKY
> I have a few services (daemons) that I start in virtual console con3 using a
> script file. It looks as follows:
> reopen /dev/con3
> service_1
> service_2
> The services use the 'procmgr_daemon' function to start into the background
> and have the PROCMGR_DAEMON_NODEVNULL flag set. All output is shown when
> selecting the virtual console (con3). Now I would like to redirect the
> outputto a file instead. For some reason I can't get it working. I tried to
> use the devc-ditto utility also started from the script file:
> devc-ditto /dev/con3 &
> reopen /dev/con3
> service 1
> service 2
> from console-1 I then try to read the output using as a test:
> cat /dev/con3.ditto &
> Unfortunatly this does not show anything. However writing directly to con 3
> using e.g. 'echo mary had a little... >/dev/con3' works and shows up in
> console-1.
> So the question is why he service output is not redirected to con1 and the
> output send directly to con3 using echo is.
> Does anyone have any idea?
> Thanks Wim
