Forum Topic - Where is pthread_rwlockattr_t documented?: (3 Items)
The Library Reference manual entry for pthread_rwlockattr_init( ) says that the sole argument is of type
pthread_rwlockattr_t, but does not appear to document the use of that struct.  Where is that information?
   Chris
RE: Where is pthread_rwlockattr_t documented?
As with all of the other pthread structures, POSIX says that the
structure itself is opaque.  The values in the attribute can be set
using the pthread_rwlock_attr_* functions.  Currently the only two are:
pthread_rwlockattr_setpshared()
pthread_rwlockattr_getpshared()
Which set or get whether the lock is shared by more than one process.
Beyond this, the structure is only used in pthread_rwlock_init() to
setup a new rwlock.
David
> From: Chris Chiesa [mailto:community-noreply@qnx.com]
> Sent: March 17, 2010 3:30 PM
> To: ostech-core_os
> Subject: Where is pthread_rwlockattr_t documented?
> type pthread_rwlockattr_t, but does not appear to document
> Thanks,
>    Chris
> http://community.qnx.com/sf/go/post49786
Re: RE: Where is pthread_rwlockattr_t documented?
Thanks, David.  After a bit of Googling I had concluded much the same (except for the bit about POSIX requiring it to be
 opaque; why THIS particular struct and not various others?  Weird).  Thanks for confirming it.
Chris
