Forum Topic - HAM - ham_action_notify_pulse: (6 Items)
I have a process that attaches itself to the HAM using ham_attach_self (name, 0, 0,0,0 );
When this process dies I would like a notification to be send to a server process that is capable of  handling pulses. I
 can retrieve the server information like pid and chid using the ConnectServerInfo call. like this
  int coid = name_open (server, 0);
  if ( coid == -1 )
      return;
   /* Retrieve server information - we need the channel id */
  if ( ConnectServerInfo(0, coid, &info) < 0 )
     return;
    name_close(coid);
This work. What I do next is register the condition and action like this:
    hc[0] = ham_condition(he, CONDDEATH, "death-condition", 0);
    if ( hc[0] )
        ha[0] = 0;
         ha[0] = ham_action_notify_pulse(hc[0], "death-action-pulse",
                                                               ND_LOCAL_NODE, info.pid, info.chid,
        HA_PULSE_DEATH, 0,
        HREARMAFTERRESTART);
      return(0);
running the process will show all the information under the /proc/ham directory but killing it will not show a
notification within the specified server. Am i doing something wrong here?
Regards
Wim
Re: HAM - ham_action_notify_pulse
can you run the ham with additional verbosity (ham -vvvvv) and then look
at the ham logs to see if the action is being triggerred. You should be
able to see the process die, and also the ham action being triggerred.
If the action is being triggered you should verify that the trigger of
the pulse contains the appropriate values as you would expect (pid, chid
etc)
thanks
shiv
Thu Mar  4 10:11:49 EST 2010
 --> According to Wim Hellenthal <--
I can retrieve the server information like pid and chid using the ConnectServerInfo call. like this
	  if ( coid == -1 )
	      return;
	     return;
	    name_close(coid);
	    if ( hc[0] )
	        ha[0] = 0;
        HA_PULSE_DEATH, 0,
	      return(0);
	Regards
	Wim
	OSTech
	http://community.qnx.com/sf/go/post48767
Shiv Nagarajan,
Kernel Developer, QNX Software Systems,
Ottawa, Canada
Hi Shiv,
I sometimes really doubt  myself. Thiking about the mail just sent I took a look at the code again and realized that I
clean up in the destructor of the HAMClient class:
       ham_detach (he, 0);
       ham_entity_handle_free (he);
How simple can it be sometimes. The question about temporary disabling heartbeat handling still stands though -:)
Wim
for the disabling part, check out the documentation of
ham_action_control, ham_condition_control and ham_entity_control
they allow enabling and disabling, also have an option to recurse into
the sub components also
shiv
Thu Mar  4 16:22:37 EST 2010
	Hi Shiv,
	       ham_detach (he, 0);
	Wim
	OSTech
	http://community.qnx.com/sf/go/post48838
Shiv Nagarajan,
Ottawa, Canada
It all works now
Thanks !!!!
Wim
Hi Shiv
Thanks for the suggestion. I'm a bit confused I have a small test program making use of the code already posted: The
code is in the file attached. When I stop the program by entering the return key no pulse is created and send the server
. When I kill the program entering Ctrl-C then a pulse is send. Why is there a difference in behaviour?
Another question is the following:
Is it possible to add heartbeat conditions and actions when a program is already attached to the HAM by the
ham_attach_self (name, 0, 0,0,0 ); routine. Or use the ham_attach_self routine with the heartbeat parameters but
temporary disable conditions and action related to heartbeat handling?
Thanks for the help!
Regards Wim
Attachment: Text HAM.txt 1.26 KB
