Forum Topic - Options to control the cursor on the terminal without using ncurses lib?: (5 Items)
Hello all.
OS:     QNX 6.4.1
Code: C
For my consolen-app it's importend to have control of the cursor.
Of course, ncurses delivers functions for that, but it was so much work to recode my app to implement ncurses.
What options do I have features like getyx(int* y, int* x) and gotoyx(int y, int x)?
Thanks for help.
Best regards,
Sven
Re: Options to control the cursor on the terminal without using ncurses lib?
refer to the devc-con docs for a list of supported ANSI screen control codes. They'll work with pterm as well.
- Thomas
Hi Thomas.
Do you mean the document from HELP-QNX Monentics IDE?
I found options to add chars and n spaces on the console, but not a function that return me the oordinates of the
current corsor position or to put the cursor on a position declared with row and colum (x, y).
Sven
Hi Sven,
to position the cursor, issue
   CSI [ <row> [ ';' <col> ] ] 'H'
where CSI is either ESC followed by '[' or 0x9B (in 8-bit-mode).
E.g., on the command line, do
   printf '\x1b[H%s' Hello
to print 'Hello' at row 0, column 0,
   printf '\x1b[%dH%s' 11 Hello
to print 'Hello' at row 11, column 0, and
   printf '\x1b[%d;%dH%s' 11 22 Hello
to print 'Hello' at row 11, column 22.
Reading the position has never really worked for me. What you can do, however, is to save and restore the cursor
position.
To save, issue
   CSI s
to restore, use
   CSI u
- Thomas
Hi Thomas.
But, how can I save the positions for e.g. n Threads?
If I correct understand CSI-command is only for one position, isn't it?
Sven
