Forum Topic - Trying to set the Endianness of a page on PPC 8548E:
Hi
Im running 6.4.1 on a PPC8548E.
Im trying to use the function shm_ctl_special  to change the endianness
of a page in memory from Big to Little Endian.
I've tried some test code (see code that follows)  which is mostly based
on the sample code for the similar function shm_ctl.
The call to shm_ctl_special seems to have no effect.  I tried the
shm_ctl_special call with and without the parameter  "PPC_SPECIAL_E".
After the call to shm_ctl_special, I read a 32 bit value from the
selected address (ptr) to the variable 'dataRead' and whether I set the
PPC_SPECIAL_E  bit or not the value of 'dataRead' does not change.
Ive also tried it with different physical addresses.  0xd0000000 is a
PCIe address space on our board.  Ive also tried it with 0xff0000000
which is our flash area.
Any help would be greatly appreciated.
Brian
#define PPC_SPECIAL_E         0x0001
#define PPC_SPECIAL_G         0x0002
#define PPC_SPECIAL_M         0x0004
#define PPC_SPECIAL_I         0x0008
#define PPC_SPECIAL_W         0x0010
void testEndianBit ()
    int         fd, memsize;
    char        *ptr, *name;
    uint64_t    physaddr;
    int         dataRead;
    name = "/wally";
    physaddr = 0xd0000000;
    memsize = sysconf( _SC_PAGE_SIZE );
    /* map in the physical memory */
    ptr = mmap_device_memory( NULL, memsize, PROT_READ|PROT_NOCACHE, 0,
physaddr );
    if ( ptr == MAP_FAILED ) {
        printf( "%s: mmap_device_memory for physical address %llx
failed: %s\n",
            progname, physaddr, strerror(errno) );
        exit( EXIT_FAILURE );
    /* open the shared memory object, create it if it doesn't exist */
    fd = shm_open( name, O_RDWR | O_CREAT, 0 );
    if ( fd == -1 ) {
        printf( "%s: error creating the shared memory object '%s':
%s\n",
                progname, name, strerror(errno) );
    if ( shm_ctl_special( fd, SHMCTL_PHYS  , physaddr, memsize,
PPC_SPECIAL_E | PPC_SPECIAL_I | PPC_SPECIAL_W) == -1 )
        printf( "%s: shm_ctl spec failed: %s\n", progname,
strerror(errno) );
        close( fd );
        munmap( ptr, memsize );
        shm_unlink( name );
    else
        printf ("special passed\n");
    dataRead = * ((int *)ptr);
     * The memory object remains in
     * the system after the close
    close( fd );
     * To remove a memory object
     * you must unlink it like a file.
     * This may be done by another process.
    shm_unlink( name );
    return EXIT_SUCCESS;
