Shared memory coherence between processes
01/10/2010 12:05 PM
post44858
I have written an A/D driver that stores samples in a circular buffer in shared memory. Upon a certain number of samples
, it pulses another process, which stores the last n samples to a file. Works fine for a while, then the file shows
zeros for a gap. When I shutdown the processes and examine the shared memory, the zeros are not there, leading me to
believe the file writer process is reading stale contents from the shared memory.
How can I make the driver process force coherence before it pulses the other application?
Re: Shared memory coherence between processes
01/11/2010 2:20 PM
post44917
> shared memory. Upon a certain number of samples, it pulses another process,
> file shows zeros for a gap. When I shutdown the processes and examine the
> shared memory, the zeros are not there, leading me to believe the file writer
> application?
mmap()ing your shared buffer PROT_NOCACHE is one approach, but may degrade performance accessing the buffer, especially
since you are batching samples.
Look at the msync() function to synchronise to physical memory. You want MS_SYNC at the writer side prior to pulsing;
you may also need to MS_INVALIDATE from the reader process after receiving the pulse (if volatile pointers are not
enough hint and no CPU bus-snooping).
There is also the cache API (libcache, refer cache_init() in the docs) which can provide more efficient memory operation
than a msync syscall (if your h/w is supported by a library variant), with CACHE_FLUSH and CACHE_INVAL taking the place
of the aforementioned msync flags, respectively.
01/11/2010 2:38 PM
post44919
You don't mention which platform this is, nor how you are setting up
your shared mappings? If you are simply
using MAP_PHYS them yes you could get cache aliasing.
A better way to handle this is to make a shared object in /dev/shmem -
that way the kernel will ensure that
processes mapping the object will have the same cache colour in the
virtual mapping.
If the mapping has to overlay a particular physical address, see shmctl(
SHMCTL_PHYS... for how to make a shared
object of that type.
samples, it pulses another process, which stores the last n samples to a file. Works fine for a while, then the file
shows zeros for a gap. When I shutdown the processes and examine the shared memory, the zeros are not there, leading me
to believe the file writer process is reading stale contents from the shared memory.
> http://community.qnx.com/sf/go/post44858
cburgess@qnx.com
01/11/2010 7:11 PM
post44973
The platform is ARM 926EJS-based. Here is what I use to create and map shmem on driver process:
shmem_fd = shm_open( HS_ADC_SHMEM_NAME, O_RDWR | O_CREAT, S_IRWXU | S_IRWXG | S_IRWXO);
ftruncate( shmem_fd, amount );
const char *adc_buf = (const char *) mmap( NULL, amount, PROT_READ|PROT_WRITE|PROT_NOCACHE, MAP_SHARED, shmem_fd, 0
On the client side:
shmem_hdl = shm_open("/adc_hs", O_RDWR, 755);
addr = (uint8_t*) mmap( NULL, amount, PROT_READ | PROT_WRITE | PROT_NOCACHE, MAP_SHARED, shmem_hdl, 0 );
I added the PROT_NOCACHE in both mmap calls since when I first posted and the problem seems to be fixed, but more
testing is required.
Todd
> virtual mapping.
> application?
> > OSTech
> cburgess@qnx.com
01/12/2010 12:14 AM
post44986
How is the driver process writing to the shared memory? Is the
peripheral writing to it or
the driver reading from the peripheral and then writing to the shared
object?
Also, what version of the OS is this for?
Colin
0 );
> On the client side:
> Thanks
> Todd
>> virtual mapping.
>> application?
>>> OSTech
>> cburgess@qnx.com
> http://community.qnx.com/sf/go/post44973
cburgess@qnx.com
01/12/2010 3:06 PM
post45094
The driver is writing directly to shared memory (after reading the peripheral over SPI).
We're using production 6.4.1.
> object?
> Colin
01/12/2010 4:09 PM
post45098
The ARM926 has a virtually indexed cache so the
memmgr is supposed to force MAP_SHARED
mappings to be uncached to avoid cache aliases.
I don't understand why explicitly adding NOCACHE
appears to fix the problem...
Sunil.
> on driver process:
> S_IRWXG | S_IRWXO);
> PROT_WRITE|PROT_NOCACHE, MAP_SHARED, shmem_fd, 0 );
> On the client side:
> problem seems to be fixed, but more testing is required.
> Thanks
> Todd
> > virtual mapping.
> writer
> other
> > application?
> > > OSTech
> > cburgess@qnx.com
01/12/2010 11:49 PM
post45113
do you say this because of the following quote from http://www.qnx.com/developers/docs/6.4.1/neutrino/prog/arm_memory.
html?
If under ARM, shared memory is *always* mapped uncached, then I fixed the problem in some other manner (or it will rear
its ugly head again during testing).
quote from ref above:
"Because the MMU transparently remaps each process's virtual address, shared memory objects must be mapped uncached,
since they're always mapped at different virtual addresses.
Strictly speaking, this is required only if at least one writable mapping exists, but the current VM implementation
doesn't track this, and *unconditionally makes all mappings uncached*.
The consequence of this is that performance of memory accesses to shared memory object mappings will be bound by the
uncached memory performance of the system. "
> Sunil.
> shmem
> > on driver process:
> > S_IRWXG | S_IRWXO);
> > On the client side:
> PROT_NOCACHE,
> the
> > Thanks
> > Todd
> > > virtual mapping.
> the
> > writer
> > other
> > > application?
> > > > OSTech
01/13/2010 4:31 AM
post45123
Yes - that's exactly what should happen.
The only shared mappings that are not forced to be uncached are:
- executable/shared library text sections.
These are read-only so even though aliases may exist they are coherent.
- SHMCTL_GLOBAL mappings.
These have a global virtual address (outside the FCSE remapped ranges)
so no aliases can exist.
Sunil.
html?
rear its ugly head again during testing).
>> Sunil.
