Forum Topic - Adaptive partitions for network: (8 Items)
Hi all,
I have QNX Neutrino 641 Eval and I am setting up adaptive partitions.
To have a separate partition for all network traffic, what are the components I have to put into?
Initially I tried to put io-pkt-v4-hc into a partition but when I do this the en0 disappears and I have to reboot the
system.
Any suggestions?
Re: Adaptive partitions for network
You might want to ask the question "what are all the networking components" in the Networking forum:
<http://community.qnx.com/sf/projects/networking>;
You may also want to move some of the clients of networking compontents to your special partition.
-ad
Victor Parera wrote:
> Hi all,
system.
> Any suggestions?
> http://community.qnx.com/sf/go/post44714
well yes, I am looking for all networking components. But I am currently very confused as to which of these go into my
partitions. Are network drivers, the stack and network manager enough? What about librariesß what about the actual /dev
 like en0 ppp0 etc? There are some network services started as system services in the sysinit. What about them? Have
these got any meaning if put in network partition?
Could you please help.
RE: Adaptive partitions for network
You just need to start the binaries in your partition.
Don't start any network components in your sysinit(if you don't want to hack up the enumerator system then you could
just slay io-pkt in your rc.local file before restarting it in your aps partition).
For example if you have the following(in your build file you've included the [module=aps] attribute to the procnto line
and created the partition via the entry: sched_aps Network 30):
$ aps
                    +---- CPU Time ----+-- Critical Time --
Partition name   id | Budget |    Used | Budget |      Used
System            0 |    70% |  15.09% |  100ms |   0.000ms
Network           1 |    30% |   0.00% |    0ms |   0.000ms
Total               |   100% |  15.09% |
In your /etc/rc.d/rc.local file you could do:
on -Xaps=Network io-pkt-v4-hc -ptcpip
on -Xaps=Network ifconfig en0 10.42.102.51 netmask 0xfffff000 up
on -Xaps=Network portmap &
on -Xaps=Network nfsd &
on -Xaps=Network inetd &
on -Xaps=Network mount -T io-pkt /lib/dll/lsm-qnet.so
on -Xaps=Network syslogd &
on -Xaps=Network /usr/sbin/fs-nfs2 stryker:/usr/qa /usr/qa &
Chris
From: Victor Parera [mailto:community-noreply@qnx.com]
Sent: Friday, January 08, 2010 4:41 AM
To: ostech-core_os
Subject: Re: Adaptive partitions for network
OSTech
http://community.qnx.com/sf/go/post44786
Not Libraries. Only threads live in partition.
You'll probably need to launch all the network driver processes your separate partition. But since I know nothing about
networking I cant tell you which ones the are. (Which is why I suggested you ask the networking guys.)
That alone may not be enough. If your network components are written as proper QNX resource managers (and I image they
are), then you may need to move the client to your networking partition too. That's because when a client sends a
Send/Receive/Reply message to a resource manager, APS automatically runs the resource manager in the partition of the
client -- not the origianl partition of the resource manager.
Sorry I can't be more specific. I just don't know enough about how the networking components.
-ad
dev like en0 ppp0 etc? There are some network services started as system services in the sysinit. What about them? Have
@Chris
I did try launching the network components like you had mentioned. However all I see is the en0 disappear. I tried
digging deeper into this.
Do you think I should mount the driver of the thernet also in this partition to get it working?
I found from /etc/system/enum/devices that my device is AMD PCNET.
Should I put all these network components plus the mount for the driver in an 'overrides' file under enum(now that it
doesnt work in rc.local or from the build files)???
@Attilla
Thank you for the explanation :)
Yes, you can just add the -dpcnet to your io-pkt line.  I'm not sure
about the overrides file?  Is that documented somewhere?
The easiest thing to do is to just slay io-pkt in the rc.local file and
then run it again in your partition.
Chris
Sent: Monday, January 11, 2010 3:50 AM
To: ostech-core_os
@Chris
However all I see is the en0 disappear. I tried digging deeper into
this.
in an 'overrides' file under enum(now that it doesnt work in rc.local or
@Attilla
OSTech
http://community.qnx.com/sf/go/post44869
Re: RE: Adaptive partitions for network
Thanks Chris.
I found the problem.
I added a 'waitfor /dev/io-net/en0' in my rc.local file after starting the tcpip stack and mounting the driver and
before doing an ifconfig
Now it all works.
Moral: Wait for the enum to enumerate io-net which then sets en0.
This post helped me:
http://community.qnx.com/sf/go/topc2211
