Forum Topic - Arbitrary shared memory file path for shm_open: (3 Items)
I noticed in the library manual of QNX 6.3 that QNX now supports arbitrary path names for shared memory files created by
 shm_open, which was not the case before(at that time only paths with one slash('/') could be used as a shared memory
file name).
So I want to know since when (which version of QNX, which year/month) did QNX operating system start supporting
arbitrary path for shared memory files?
Thanks.
RE: Arbitrary shared memory file path for shm_open
> From: David Zhao [mailto:david.zhao@oracle.com]
> Sent: September 21, 2007 12:45 AM
> To: ostech-core_os
> Subject: Arbitrary shared memory file path for shm_open
> by shm_open, which was not the case before(at that time only
> paths with one slash('/') could be used as a shared memory file name).
As far as I can tell, we have always supported them.  What is
different is that the documentation didn't reflect this.
At least on the library side, we have always supported the
creation of a 'local' shared object if you didn't specify
a leading / on the name.
What are you trying to accomplish?
Hope this helps,
 Thomas
Re: RE: Arbitrary shared memory file path for shm_open
Thanks, this is good news.
We are developing the Oracle Berkeley DB product, which is a very powerful, efficient and scalable embeded database
library widely used on various platforms, ranging from embeded systems to high-end servers.
Berkeley DB has a QNX port, and we are testing our product for portablilty on latest version of QNX.
For previous versions of QNX, there was a path conversion workaround for shm_open path names in BDB, may be it is no
longer needed now. :)
Thanks.
