12/17/2009 12:22 PM
post44041
"strace" I meant to write, instead of "ptrace"...
12/17/2009 1:21 PM
post44046
go for:
http://www.qnx.com/developers/docs/6.4.1/instr_en/instr/about.html
to start, it shows all you need
If you have tracelogger running in ring mode you may stop recording with
TraceEvent(_NTO_TRACE_STOP);
TraceEvent(_NTO_TRACE_FLUSHBUFFER);
this only stops recording, you will have to terminate tracelogger
$ slay tracelogger
before accessing the log file.
if logger wrapped the ring you're loosing process names in your log file, so an additional pidin will help to read the
log
I guess you will need to run tracelogger in wide mode (-w) to get more data on your MsgSnd calls (not all the data is
logged!)
HTH
/hp
-----Ursprüngliche Nachricht-----
Von: Marc Roessler [mailto:community-noreply@qnx.com]
Gesendet: Do 17.12.2009 17:31
An: ostech-core_os
Cc:
Betreff: Syscall tracing
I'm trying to trace a problem I'm seeing with a resource manager.
Background:
In the iomsg handler function, the io_msg_t message that is passed to it sometimes has a msg_hdr.i.combine_len field of
zero or an unexpected msg_hdr.i.mgrid value.
I suspect this is either from memory corruption in the client or the server (ResMgr), but it's not clear for me where
corruption of this header is really happening.
Now I would like to either
a) some sort of ptrace the client process to see what it is sending
or
b) do a kernel trace that is triggered after the Client's "syscall" has returned unsuccessfully, as a post-trigger, i.e.
the ring buffer stops recording when the user pulls the trigger.
Concerning a) there seems to be dtrace, but it doesn't seem really usable yet. (?)
Concerning b), there is lots of info about the instrumented kernel, that you can inject user specified events, etc etc..
. but this all seems to me more like an overview, I haven't found any real examples on how post-triggering is done (can
it be done?), or how filters can be installed. Also this seems a bit of overkill just for finding out what data is
actually sent using MsgSend...
Any suggestions?
Marc
OSTech
http://community.qnx.com/sf/go/post44033
