Forum Topic - Cool posting about devc-ditto: (7 Items)
Hi all,
There's a new SRR article by guest author Xiaodan Tang on devc-ditto.
Kudos to Xiaodan for making such a useful utility!
http://sendreceivereply.wordpress.com/2007/09/14/devc-ditto-the-principle-the-usage/
cburgess@qnx.com
Re: Cool posting about devc-ditto
So here are some ideas I had that could still be done.
qtalk obviously has a few issues - maybe we would still do a 'ditto' util, that makes it more convenient.
For example...
ditto /dev/con1 could automatically open /dev/con1.ditto, if present
ditto handle the old ditto options...
$ use ditto
ditto [options]* [path-to-device]
Options:
 -c command_char  Enter command mode on this character (hex value).
          (Default is ^E)
 -f               Follow "active" console.
 -k               Enable local keyboard.
 -q               Quiet operation; don't notify target being watched.
 -n nid           Node to ditto
 -t ttyno         TTY to ditto
Following the 'active' console would be nice, but would be pretty hard.  However you could auto switch on 'input' maybe.
cheers,
Colin
cburgess@qnx.com
Devc-ditto ... very close to old qnx4 ditto. Well done!
But now I am struggling with "ditto-ing" real console (/dev/con2) from telnet session.
I have compiled devc-ditto (on QNX6.4 alpha), started it, mounted ditto on /dev/con2.
Using qtalk from telnet session I can "interact" with /dev/con2 (through /dev/con2.ditto), but the output seems "messy"
- seems like CR/LF problem. Output moves to next line, but doesn't move to its beginning.
Any ideas?
Thanks, PKY
RE: Cool posting about devc-ditto
Once in qtalk (to /dev/con2.ditto), do a:
	stty raw </dev/con2
This should give you better output.
-xtang
> From: Pavol Kycina [mailto:community-noreply@qnx.com]
> Sent: August 28, 2008 5:04 AM
> To: ostech-core_os
> Subject: Re: Cool posting about devc-ditto
telnet
> session.
ditto on
> /dev/con2.
(through
> /dev/con2.ditto), but the output seems "messy" - seems like CR/LF
problem.
> Any ideas?
> Thanks, PKY
> http://community.qnx.com/sf/go/post12524
Re: RE: Cool posting about devc-ditto
> 	stty raw </dev/con2
> -xtang
[snip]
The look in qtalk is exactly the same even with "stty raw </dev/con2".
After issuing this command the output on "original" /dev/con2 gets "spoiled" in the same way as in qtalk. After issuing
"stty edit </dev/con2" output on real console gets repaired, nothing changes in qtalk.
Anything else to try?
Thanks, PKY
RE: RE: Cool posting about devc-ditto
Did you type the command WITHIN the qtalk (not from some other terminal,
but inside qtalk) ?
-xtang
> Sent: Wednesday, September 03, 2008 2:14 AM
> To: ostech-core_os
> Subject: Re: RE: Cool posting about devc-ditto
> > 	stty raw </dev/con2
> > -xtang
> [snip]
> Thanks, PKY
> http://community.qnx.com/sf/go/post12723
Re: RE: RE: Cool posting about devc-ditto
> but inside qtalk) ?
> -xtang
[snip]
Yes, I typed the command within the qtalk.
PKY
