SIGSEGV in InterruptUnlock / __inline_InterruptEnable
11/03/2009 5:11 AM
post41202
I am getting SIGSEGV during InterruptUnlock / __inline_InterruptEnable
The piece of code that causes this fault is as follows:
InterruptLock(&_intr_lock);
/* couple of pci config writes */
InterruptUnlock(&_intr_lock);
I/O privileges have been obtained for this thread with:
ThreadCtl(_NTO_TCTL_IO, 0);
Can a Threads I/O privileges be lost at runtime? If so, what can cause it?
Are there any other reasons for a SIGSEGV to be generated during Interrupt Enable/Disable?
The code is running on a BCM1250 (MIPS) based H/W running ONX 6.3
Regards
Chaitanya
RE: SIGSEGV in InterruptUnlock / __inline_InterruptEnable
11/03/2009 7:54 AM
post41208
Do your /* couple of pci config writes */ work fine without the
InterruptLock() / InterruptUnlock() around them???
----Original Message----
From: Chaitanya Huilgol [mailto:community-noreply@qnx.com]
Sent: Tuesday, November 03, 2009 3:42 PM
To: ostech-core_os
Subject: SIGSEGV in InterruptUnlock / __inline_InterruptEnable
> can cause it?
> Regards
> Chaitanya
> http://community.qnx.com/sf/go/post41202
Re: RE: SIGSEGV in InterruptUnlock / __inline_InterruptEnable
11/03/2009 8:54 AM
post41216
I haven't tried the PCI writes without the Interrupt lock, And the code had been running fine without issues for quite
sometime.
Is the Interruptlock not required around the PCI writes?
11/03/2009 9:19 PM
post41276
If there is no specific reason, I don't see a point to use InterruptLock/Unlock. You better not to use kernel call
within your IntterptLock/Unlock. Pci write will call pci server that involves kernel calls.
RE: RE: SIGSEGV in InterruptUnlock / __inline_InterruptEnable
11/04/2009 12:57 AM
post41279
The PCI writes correspond to
PCI write to set a bit
Short delay (for loop counter)
PCI write to clr a bit
And this needs to be atomic so that the thread does not get scheduled out in the middle, hence it has been protected by
the Interrupt locks
From: Lichun Zhu [mailto:community-noreply@qnx.com]
Sent: Wednesday, November 04, 2009 7:50 AM
To: ostech-core_os
Subject: Re: RE: SIGSEGV in InterruptUnlock / __inline_InterruptEnable
OSTech
http://community.qnx.com/sf/go/post41276
11/03/2009 9:37 AM
post41220
Did you check the return code from ThreadCtl() to make sure that it was
successful?
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
> Sent: Tuesday, November 03, 2009 5:12 AM
> To: ostech-core_os
> can cause it?
> Regards
> Chaitanya
11/04/2009 1:24 AM
post41280
I have checked the return value of ThreadCtl, Also the issue does not occur immediately. Privileged I/O accesses do go
through without causing SIGSEGV before this issue is hit
Regards
Chaitanya H
From: Steve Reid [mailto:community-noreply@qnx.com]
Sent: Tuesday, November 03, 2009 8:08 PM
To: ostech-core_os
Subject: RE: SIGSEGV in InterruptUnlock / __inline_InterruptEnable
successful?
Technical Editor
> To: ostech-core_os
> can cause it?
> Regards
> Chaitanya
OSTech
http://community.qnx.com/sf/go/post41220
11/04/2009 1:28 AM
post41281
Could you give the complete code please (/* couple of pci config writes
*/)? Are you sure you are not doing anything that may cause sleep /
reschedule as it is illegal to do that after you do InterruptLock().
Rajat
Sent: Wednesday, November 04, 2009 11:54 AM
To: ostech-core_os
> Regards
> Chaitanya H
> To: ostech-core_os
> that it was
> successful?
> Technical Editor
>> -----Original Message-----
>> To: ostech-core_os
>> Hi,
>> can cause it?
>> Regards
>> Chaitanya
>> OSTech
> http://community.qnx.com/sf/go/post41280
11/04/2009 2:26 AM
post41282
The actual code is as follows:
mapped_pci_mem_write(signal);
pci_conf_write(0,0,0,PCI_INTA_REG,1)
for(i=0; i < DELAY_INTERVAL; i++) {};
pci_conf_write(0,0,0,PCI_INTA_REG,0)
The mapped_pci_mem_write writes into mapped pci device memory. I am not seeing anything that may cause sleep.
If the thread tries to sleep after a lock, would a crash occur while scheduling out the thread or issues like currently
observed during InterrupUnlock
Can any other info be collected (such as thread privileges etc.) to better understand the issue?
Regards
Chaitanya
From: Rajat Jain [mailto:community-noreply@qnx.com]
Sent: Wednesday, November 04, 2009 11:58 AM
To: ostech-core_os
Rajat
To: ostech-core_os
> Regards
> Chaitanya H
> To: ostech-core_os
> that it was
> successful?
> Technical Editor
>> To: ostech-core_os
>> Hi,
>> can cause it?
>> Regards
>> Chaitanya
>> OSTech
11/10/2009 1:03 PM
post41730
currently observed during InterrupUnlock
> Regards
> Chaitanya
> To: ostech-core_os
> Thanks,
> Rajat
> To: ostech-core_os
> > Regards
> > Chaitanya H
> > To: ostech-core_os
> > that it was
> > successful?
> > Technical Editor
> >> To: ostech-core_os
> >> Hi,
> >> can cause it?
> >> Regards
> >> Chaitanya
11/10/2009 1:12 PM
post41732
It is directly writing into the mapped address space. pci_write_config call is not being used.
Regards
Chaitanya
Sent: Tuesday, November 10, 2009 11:34 PM
To: ostech-core_os
> Regards
> Chaitanya
> To: ostech-core_os
> Thanks,
> Rajat
> To: ostech-core_os
> > Regards
> > Chaitanya H
> > To: ostech-core_os
> > that it was
> > successful?
> > Technical Editor
> >> To: ostech-core_os
> >> Hi,
> >> Can a Threads I/O privileges be lost at runtime? If so,...
