Re: nano_trace.c - waste of buffer space
11/03/2009 2:06 PM
post41251
> with my first ring mode kernel trace from a 6.4.1 system I was running in a,
> at first sight, strange thing.
> The trace didn't have the expected size.
> With ring mode trace you used to have always a kev size of n-kbufs*16KB
> This is now changed, I think because of event data truncation at buf end - at
> least this was a PR we had filed in the past.
> But this change was a hard one.
> in nano_trace.c you now switch buffers when there are about 300 slots left.
> The problem with this is that I used ring mode tracing as the one with the
> least system impact for limited systems.
> As on these systems I also have low memory conditions, the amount of usable
> kernel buffers is also low - and remember each kbuf has to be contigous memory
> So now I am losing 30% of recording time, because buffer space is just not
> used and I can't just increase num of k-bufs.
> what do you think about changeing this threshold to a bit a "smarter" one?
> /hp
hey ho Mr. Trace (cb) or somebody else
no comments on this?
