Forum Topic - QNX *.da files does it collects cumulative across two different test cases.: (17 Items)
Can you please let me know which below version of the following compilers give us cumulative results for coverage data
files(*.da)
1. "ntomips-gcov OR ntomips-gcov-2.95.3"
2. gcov (GCC) 3.3.5 (qnx-nto) - which is (ntomips-gcov-3.3.5)
Re: QNX *.da files does it collects cumulative across two different test cases.
can someone please reply for this query?
 files(*.da)
As I said before you have to use right version of the gcov tool for the
compiler (e.g. ntomips-gcov-3.3.5 for gcc 3.3.5).
Here is a simple example of getting cumulative results:
# cat simple.c
#include <stdio.h>
  if (argc > 1) {
   printf("foo\n");
  } else {
   printf("bar\n");
# qcc -V3.3.5,gcc_ntomipsbe -ftest-coverage -fprofile-arcs simple.c -o
simple
On the target doing multiple runs:
# ./simple
bar
# ./simple 1
foo
# ./simple 2
foo
# ./simple 3
foo
On the host side:
# ntomips-gcov-3.3.5 -f simple.da
100.00% of 4 lines executed in function main
100.00% of 4 lines executed in file simple.c
Creating simple.c.gcov.
# cat simple.c.gcov
         -:    0:Source:simple.c
         -:    0:Object:simple.bb
         -:    1:#include <stdio.h>
         -:    2:
         4:    3:int main(int argc, char *argv[]) {
         4:    4: if (argc > 1) {
         3:    5:  printf("foo\n");
         -:    6: } else {
         1:    7:  printf("bar\n");
         -:    8: }
         -:    9:}
         -:   10:
As you can see from the generated gcov file code coverage data is
collected from multiple runs.
Ryan Mansfield
thanks a lot for the example.
the problem with 3.3.5 compiler here is that the binary is bloated up by 4 times larger compare to 2.95.3.
So can you please let me know wether this cumulative results are collected with the 2.95.3 compiler and the 2.95.3 gcov
versions?
thanks in advance
Why would you even ask about using gcov 3.3.5 if you had no intention of
using it?
I haven't seen such a significant increase in code size. Can you provide
an example? Are you compiling with debug information? Are you comparing
the size of the binary on size or the size of the loable segments?
Ryan Mansfield
gcov versions?
I just remembered that 2.95.3 did not use the __bb_exit_funcs from the
gcc 2.95.3 libgcc (which does merge data) but instead uses a custom
__bb_exit_funcs from libc.a and this routine did not merge the existing
data.
The attached libc.a contains a gmon.o that will merge the existing .da
file. You will need to relink your application to pick up the fix.
Please let me know if you have any problems.
Ryan Mansfield
Attachment: Text mipsbe-libca.tar.gz 406.26 KB
I had tried this new libc.a by newly compiling binary and the *.da not getting cumulative results for different
executions.
Please help here.
the reason we try 3.3.5 compiler is because of this cumulative feature, if the patch is available for the 2.95.3 itself
we wont use 3.3.5 comipler/gcov tool.
Nagaraj naik wrote:
executions.
How did you test it? Did you try following my example of how to use code
coverage? Can you please tell me exactly what you are trying? Where did
you install the libc.a on the host?
Let me illustrate for you that with the libc.a code coverage works with
2.95.3:
On host:
# qcc -V2.95.3,gcc_ntomipsbe simple.c -ftest-coverage -fprofile-arcs -o
simple
On target:
# ./simple
bar
# ./simple 1
foo
# ./simple 2
foo
# ./simple 3
foo
On host again:
# ntomips-gcov-2.95.3 -f simple.da
100.00% of 6 source lines executed in function main
No executable source lines in function _GLOBAL_$I$mainGCOV
100.00% of 6 source lines executed in file simple.c
# cat simple.c.gcov
		#include <stdio.h>
            4     if (argc > 1) {
            3      printf("foo\n");
            3     } else {
            1      printf("bar\n");
            4     }
            4    }
> Please help here.
Please provide an example or a better description of what does not work
for you. If you cannot disclose details about your problem in the forum
and need further assistance with the usage issues I suggest you contact
our support department. They can confidentially work with you and get
past whatever is holding you back from providing details.
Ryan Mansfield
What i did here is that
I had put the latest libc.a file under <qnx/target/qnx6/mipsbe/lib/>
1.compiled the program, and
2. I tried some test cases that covers line 1 to 5
3. and then rebooted the system.
4. i had put last *.da files back in place
5. tried another test case whcih covers 8 to 10 lines.
and then tried gcov 2.95.3 and i see only 8 to 10 lines are tocuhed that means its overwritten the file.
does this libc.a should be installed on host side of it, not on the target like i did above, please let me know.
If its on host side, please let me know which directory should i keep this libc.a
Yes, it needs to be installed on host side.  libc.a is a static archive
and as I explained in a previous email, your application needs to use
the updated gmon.o from libc.a.
Unless linking your executable on your target (not likely) there is no
point in having a libc.a on the target.
Ryan Mansfield
thanks
can you please tell me where on host side need to be installed this libc.a
Nagaraj naik wrote:
> thanks
$QNX_TARGET/mipsbe/lib/libc.a
Sorry, I didn't figure I needed to tell you exactly where since there is
only one libc.a per architecture on the host and it's easy to find using
a utility like find or Windows search. You can back up the existing
libc.a and replace it with the new one using 'cp'.
Ryan Mansfield
Yes, as you provided earlier libc.a fix for nomral gcov is getting "aborted" error.
like that I have installed libc.a on the same as you mentioned
i.e. at $QNX_TARGET/mipsbe/lib/libc.a
earlier you had given me following files with the fix, let me know if we are missing anything here other than libc.a
libc.so, libcS.a, libc.a, libc.so.2
and by putting libc.a at above location only i had tried my test cases but its not accumalating the results in *.da
files.
please help.
Yes, those files are on your host not your the target. I'm not sure why
earlier you said you had installed them on your target?
This fix was in gmon.o and gmon.o is only in the archive variant. If you
are having troubles linking against the proper libc.a you can extract
the libc.a and explicitly link the gmon.o into your executable.
files.
> please help.
I am only going to ask these questions once more. Can you provide your
testcase? Did you try my example?
Ryan Mansfield
I have done with your simple.c program
#qcc -V2.95.3,gcc_ntomipsbe -Wc, -fprofile-arcs -Wc, -ftest-coverage   -c -o simple.o simple.c
#qcc -V2.95.3,gcc_ntomipsbe -o simple  simple.o /vobs/projects/springboard/tps/qnx/target/qnx6/mipsbe/lib/libc.a -
Bstatic
# ./simple
bar
# ./simple 1
foo
# ./simple 2
foo
# ./simple 3
foo
#ntomips-gcov-2.95.3 simple.c
 83.33% of 6 source lines executed in file simple.c
#cat simple.c.gcov
                #include <stdio.h>
           1      if (argc > 1) {
           1       printf("foo\n");
           1      } else {
      ######       printf("bar\n");
           1      }
           1    }
here it got the data which was last executed.
i had attached all the simple.c, libc.a, simple.bb, simple.bbg and simple.c.gcov all i had used, please let me know
where might be wrong here.
the filesystem here where I am running this program is DRAM based file system.
I tried the same simple.c with 3.3.5 its going through fine here.
Attachment: Text simple.tar.gz 462.95 KB
The problem is that embedded filename for the .da file is:
/vobs/projects/springboard/npfos/platform/scimitar/shell/simple.da
Presumably you don't have access to this path on your target so the when
code coverage code fails to open the embedded filename it ends up
writing a new .da file using the file's basename to the current working
directory. I've modified gmon.c code in libc.a to check for the
existence of a <basename>.da file and merge in code coverage data if it
exists and the arcs match.
Attached is a new libc.a.
Ryan Mansfield
Attachment: Text mipsbe-fix.tar.gz 406.31 KB
Thanks a lot.
It solved the problem for cumulative coverage data here.
it was a great timely response from you, thanks again.
will keep in touch with official support channel inorder to get the official fix for the same along with you being in
loop.
