Re: detection of scoid leaks
10/23/2009 12:56 PM
post40628
Yes, I agree, that by good coding standard you can avoid this type of trouble.
But mistake can happen anytime, and it would be nice to have a tool to diagnose the system with "check list approach". E
.g. check for memory leaks (pidin mem), check for fd leaks (pidin fd), ... And hopefully sometimes scoid leaks (pidin
scoid). ;-)
Pavel
> Pavol,
> Although we offer several ways of tracking associated resources such as coid's
> , fd and channels, there is no tool to examine scoid's.
> It is my personal belief that if you start will a good template for your
> server, and if you understand the design issues fairly well, your desire for
> such a tool will diminish.
> Also, note that it most cases, the recommended way of implementing a server
> is to use the resource manager framework, and in the case the notion of scoid
> is hidden inside the framework and you don't need to handle it, or even be
> aware of it.
> -Chris
