Forum Topic - Virutal to Physical Address Conversion: (4 Items)
Greetings,
Does anyone know of a way to convert virtual addresses from other processes into their physical address in ram? I'd like
 to have a monitoring process go through all the running processes and find where their code/data section is in ram. Any
 suggestions would be great. Thanks.
AW: Virutal to Physical Address Conversion
shortest answer: try pidin and showmem sources
-----Ursprüngliche Nachricht-----
Von:	Hayder Mouhammed [mailto:community-noreply@qnx.com]
Gesendet:	Di 17.03.2009 18:17
An:	osmeta-core_os
Cc:
Betreff:	Virutal to Physical Address Conversion
Greetings,
OSMeta
http://community.qnx.com/sf/go/post24587
Attachment: Text winmail.dat 3.43 KB
Re: AW: Virutal to Physical Address Conversion
If I use "pidin mem", "pidin pmem", showmem, I can see how big the code/stack size is and virtual addresses, but how can
 you get another process to translate that process' virtual address. Example: all processes return the beginning of
their code space as 0x48040000, but if you try to use mphys() that will return the physical address of the monitoring
process.
AW: AW: Virutal to Physical Address Conversion
I don't see a chance for you as long as you try to do this from a different process.
This would break some fundamental memory protection issues.
The mapping tables (v -> p) are stored in procs memory.
What about doing a bit different:
write a SO that is including either a signal handler or a very simple resmgr and also the functionaloty needed to map
the virt -> phys stuff.
having this SO, you could use LD_PRELOAD so that this lib is loaded additionaly with the process you want to moinitor.
then, when ever you want the mappings you send a signal or simple string to the resmgr and the libs is doing what it
should.
This way you can work inside of you process
Gesendet:	Di 17.03.2009 19:15
An:	osmeta-core_os
Cc:
Betreff:	Re: AW: Virutal to Physical Address Conversion
process.
OSMeta
http://community.qnx.com/sf/go/post24602
Attachment: Text winmail.dat 3.9 KB
