Re: AMD vs Intel QNX Install question
10/08/2008 6:47 PM
post14730
> I apologize if this question is in the wrong forum. Also I am a virtual QNX
> newbie. I have some Unix/Linux experience, but mainly DOS/Windows. My
> problem is I have an old ISA computer running QNX. The CPU was replaced, but
> I believe the original CPU was an Intel and it was replaced with an AMD.
That must be very old because I didn't know AMD made Intel pin compatible processors .
> The install doesn't like that. The boot goes like this:
> /bin/Fsys terminated (SIGSEGV) at 0005:0001B609
> Path=0 -IDE
> target=0 lun=0 Direct-Access(0)- FUJITSU MPE3136A Rev:
> mount -p: open() on /dev/hd0 failed: No such file or directory
> Prior to the last line there was an error at the top of the screen saying
> something like error opening Fsys.bin (not sure of the file extension).
> My newbie question is, is it an easy change to configure for an AMD processor
> instead of an Intel processor. Is it as easy as replacing some files with the
> AMD version?
QNX4 doesn't care about processor model/brand. There is nothing to change in fact there is nothing that can be changed
If so, can someone let me know which files I need to replace?
> Otherwise I have to look around for an appropriate Socket A Intel processor.
Socket A is AMD only, I couldn't have been an Intel CPU in the first place.
Why was the CPU changed in the first place, sounds to me like you have a hardware problem which is causing Fsys to crash
> Thanks or any help!
> Bob
10/08/2008 6:48 PM
post14731
Fsys means it QNX4. A more appropriate forum is : http://community.qnx.com/sf/discussion/do/listTopics/projects.
community/discussion.qnx4_community_support
