can't create pipe - try again from telnet shell
06/06/2008 2:48 PM
post8849
Big loop shell script runs a long time and then crashes with error message:
./runloop[25]: can't create pipe - try again
After this error the shell seems to have lost its enviroment or has gotten
into some wacko state. The only way I know to clear this problem
is to reboot, even if I log out and open a new shell the system
does not recover. I see this happening every few days but have not
precisely correlated it with the things that I am doing.
All suggestions welcome,
Augie Mattheiss
http://civspace.jhuapl.edu/
# cat runloop1
#!/bin/sh
date
loopcnt=0
looplist="1 2 3 4 5 6 7 8 9 10"
#looplist="1 2"
for index6 in $looplist ; do
for index5 in $looplist ; do
for index4 in $looplist ; do
for index3 in $looplist ; do
for index2 in $looplist ; do
for index1 in $looplist ; do
pciwrite 0x11aa 0x1770 0 2 0 $loopcnt
PCIREADANS=$(pciread 0x11aa 0x1770 0 2 0)
# echo $loopcnt $PCIREADANS
printf "%d should == %X\n" "$loopcnt" "$PCIREADANS"
let loopcnt=loopcnt+1
# sleep 1
# date
done
done
done
done
done
done
date
> ./runloop1[25]: can't create pipe - try again
login: root
sh: /etc/profile[21]: can't create pipe - try again
sh: /root/.profile[5]: can't create pipe - try again
# ls
Re: can't create pipe - try again from telnet shell
06/10/2008 4:37 AM
post8904
> Augie Mattheiss
> # cat runloop1
> #!/bin/sh
> date
> loopcnt=0
> #looplist="1 2"
> # sleep 1
> # date
> done
> done
> done
> done
> done
> done
> date
> login: root
> # ls
Is pipe running ?
/root# which pipe
/sbin/pipe
/root# pidin -ppipe
pid tid name prio STATE Blocked
486264928 1 sbin/pipe 10r SIGWAITINFO
486264928 2 sbin/pipe 10r RECEIVE 1
486264928 3 sbin/pipe 10r RECEIVE 1
486264928 4 sbin/pipe 10r RECEIVE 1
486264928 5 sbin/pipe 10r RECEIVE 1
Hope this helps.
Jeevan
AW: can't create pipe - try again from telnet shell
06/11/2008 4:01 AM
post8961
Hi Augie,
...how are you starting that script?
Can you post the command line?
Do you do any redirection?
Does the script run a while, or fail immediately?
Maybe you're running out of either fds or memory - the docs for pipe()
(which is the function failing here) list the following error causes:
EMFILE - The calling process doesn't have at least 2 unused file
descriptors available.
ENFILE - The number of simultaneously open files in the system would
exceed the configured limit.
ENOSPC - There's insufficient space available to allocate the pipe
buffer.
ENOSYS - There's no pipe manager running.
EROFS - The pipe pathname space is a read-only filesystem.
I attached a version of ksh that should, together with "can't create
pipe",
display the error string.
In case of EMFILE, ENFILE, or ENOSPC, you could e.g. monitor the
resource
usage in your system with
pidin info (for overall memory usage)
pidin fd (for fds usage)
Hope this helps...
- Thomas Haupt
> -----Ursprungliche Nachricht-----
> Von: Augie Mattheiss [mailto:augie.mattheiss@jhuapl.edu]
> Gesendet: 06 June 2008 20:49
> An: osmeta-core_os
> Betreff: can't create pipe - try again from telnet shell
> error message:
> or has gotten
> Augie Mattheiss
> # cat runloop1
> #!/bin/sh
> date
> loopcnt=0
> #looplist="1 2"
> # sleep 1
> # date
> done
> done
> done
> done
> done
> done
> date
> login: root
> # ls
> OSMeta
> http://community.qnx.com/sf/go/post8849
06/16/2008 2:16 AM
post9157
Hi Augie,
buffer.
pipe",
resource
Hope this helps...
- Thomas Haupt
> An: osmeta-core_os
> error message:
> or has gotten
> Augie Mattheiss
> # cat runloop1
> #!/bin/sh
> date
> loopcnt=0
> #looplist="1 2"
> # sleep 1
> # date
> done
> done
> done
> done
> done
> done
> date
> login: root
> # ls
> OSMeta
RE: can't create pipe - try again from telnet shell
06/16/2008 10:39 AM
post9183
Thomas
Unfortuately I have had the problem after updating the shell
application. But I do now know that the pipe process is stopping.
Do I have any options for trying to determine why the pipe
process stops? I can easily restart it and things start working
again so this is no longer a significant issue but, obviously
long term, I'd like to figure out what is happening.
Thanks for your help,
Augie
looptest01
generally no, but sometimes I do use indirection
Most of the time the script runs normally all the way
through completion (it takes minutes and does lots
of terminal (stdout) I/O), I have not
correlated what I am doing with this unable to create
pipe issue.
Sent: Monday, June 16, 2008 2:17 AM
To: osmeta-core_os
Subject: AW: can't create pipe - try again from telnet shell
Hi Augie,
buffer.
pipe", display the error string.
resource usage in your system with
Hope this helps...
- Thomas Haupt
> An: osmeta-core_os
> message:
> gotten into some wacko state. The only way I know to clear this
> problem is to reboot, even if I log out and open a new shell the
> system does not recover. I see this happening every few days but have
> not precisely correlated it with the things that I am doing.
> Augie Mattheiss
> # cat runloop1
> #!/bin/sh
> date
> loopcnt=0
> #looplist="1 2"
> # sleep 1
> # date
> done
> done
> done
> done
> done
> done
> date
> login: root
> sh: /root/.profile[5]: can't create pipe - try again # ls
06/16/2008 11:15 AM
post9194
Hi Augie,
> application.
No surprise at all - the only change I made was to print out
a more informative error message when pipe creation failed,
so I didn't expect it to actually perform any better... 8-)
That's good. Does 'stopping' mean, 'go into STOPPED state',
'terminate' or 'crash'?
> process stops?
...hm... if "pipe" actually crashes and you have "dumper" running,
we might be able to make something out of the core file. I'll build
a debug-"pipe" and post here, so it's easier to analyze...
What target platform was that again?
Good to know.
Cheers,
- Thomas
> Augie
> looptest01
> pipe issue.
> From: Thomas Haupt [mailto:thaupt@qnx.com]
> To: osmeta-core_os
> Hi Augie,
> system would
> buffer.
> Hope this helps...
> - Thomas Haupt
> > An: osmeta-core_os
> > message:
> days but have
> > Augie Mattheiss
06/19/2008 6:17 AM
post9420
Hi Augie,
...sorry for the delay. Attached is a debug version of 'pipe',
'pipe_g'. Could you run that instead of the regular pipe manager,
make sure 'dumper' is running, then provoke your 'can't create pipe'
error, see if a 'pipe_g.core' file was produced, and if so, send
that to me ?
- Thomas
> Gesendet: 16 June 2008 16:39
> An: osmeta-core_os
> Betreff: RE: can't create pipe - try again from telnet shell
> Thomas
> Augie
> looptest01
> pipe issue.
> To: osmeta-core_os
> Hi Augie,
> system would
> buffer.
> Hope this helps...
> - Thomas Haupt
> > An: osmeta-core_os
> > message:
> days but have
> > Augie Mattheiss
06/19/2008 8:48 AM
post9422
Thomas
I will do what you ask, it may take some time for the problem
(assuming it isn't corrected with this change, of course...)
to pop back up. The "can't create pipe" problem actually hasn't
happened in the past few days. We also may not rely heavily on
scripting if an approach to use L3's InControl ground control
system to "drive" a Neutrino/hardware front-end works out.
Augie
Sent: Thursday, June 19, 2008 6:18 AM
To: osmeta-core_os
Hi Augie,
...sorry for the delay. Attached is a debug version of 'pipe', 'pipe_g'.
Could you run that instead of the regular pipe manager, make sure
error, see if a 'pipe_g.core' file was produced, and if so, send that to
me ?
- Thomas
> An: osmeta-core_os
> Thomas
> Do I have any options for trying to determine why the pipe process
> stops? I can easily restart it and things start working again so this
> is no longer a significant issue but, obviously long term, I'd like to
> Augie
> looptest01
> Most of the time the script runs normally all the way through
> completion (it takes minutes and does lots of terminal (stdout) I/O),
> I have not correlated what I am doing with this unable to create pipe
> issue.
> To: osmeta-core_os
> Hi Augie,
> would
> buffer.
> Hope this helps...
> - Thomas Haupt
> > An: osmeta-core_os
> > Big loop shell script...
