Not able to install QNX Software Center
02/03/2023 6:37 AM
post122131
Facing issue while installing QNX software center. Following is the log and attached the screenshot of the issue.
Anyone faced the same issue and resolved? Any hint to resolvethe issue is appreciated.
chmod a+x qnx-setup-2.0-202209011607-linux.run
./qnx-setup-2.0-202209011607-linux.run
2023-02-03 06:39:26 INFO com.qnx.swupdate.log.JdkLoggingConfigurer - log config system property not set (set -Djava.util
.logging.config.file=/path/to/logging.properties' to override default log config)
2023-02-03 06:39:26 INFO com.qnx.swupdate.log.JdkLoggingConfigurer - log config file override not present (create '/home
/kpit/qnx/qnxsoftwarecenter/configuration/qnxsoftwarecenter.logging.properties' to override default log config)
2023-02-03 06:39:26 INFO com.qnx.swupdate.log.JdkLoggingConfigurer - configuring logging with default settings
2023-02-03 06:39:26 INFO com.qnx.swupdate.log.JdkLoggingConfigurer - using log pattern: /home/kpit/.qnx/swupdate/
qnxsoftwarecenter-%g.log
2023-02-03 06:39:26 INFO com.qnx.swupdate.log.LogActivator - ### logging system initialized ###
os.arch=amd64
os.name=Linux
os.version=5.15.0-58-generic
osgi.configuration.area=file:/home/kpit/qnx/qnxsoftwarecenter/configuration/
osgi.install.area=file:/home/kpit/qnx/qnxsoftwarecenter/
osgi.instance.area=file:/home/kpit/.qnx/swupdate/
platform log file=/home/kpit/.qnx/swupdate/.metadata/.log
logger pattern=/home/kpit/.qnx/swupdate/qnxsoftwarecenter-%g.log
2023-02-03 06:39:26 INFO com.qnx.swupdate.core.SwUpdateCoreActivator - configuring default proxy
2023-02-03 06:39:26 INFO com.qnx.swupdate.core.SwUpdateCoreActivator - configuring default auth
2023-02-03 06:39:27 FINE com.qnx.swupdate.common.http.client4.HttpClient4Provider - authenticator set to
TwoPhaseAuthenticator [qnxAuthClient=com.qnx.swupdate.common.http.client4.auth.ExternalAuthClient@64030b91,
swupdateAuthClient=SwupdateUserAuthClient [loginURI=http://notset/login], credentialProvider={MYQNX=com.qnx.swupdate.
core.credentials.CredentialProviderRegistryAuthenticationCredentialProvider@77a281fc}]
2023-02-03 06:39:27 INFO com.qnx.swupdate.core.p2.CoreP2Activator - setting active profile to null
2023-02-03 06:39:27 INFO com.qnx.swupdate.app.Application - QNX Software Center version: 2.0:v202209011607
2023-02-03 06:39:27 INFO com.qnx.swupdate.app.Application - starting UI
2023-02-03 06:39:27 INFO com.qnx.swupdate.app.Application - layout did not change 6
2023-02-03 06:39:28 INFO com.qnx.swupdate.core.activation.QSCHeartbeatClient - License heartbeats are enabled
(automatically)
2023-02-03 06:39:28 FINE com.qnx.swupdate.common.util.SignedFileReader - Reading and verifying signed data from file /
home/kpit/.qnx/license/ownership
2023-02-03 06:39:28 FINE com.qnx.swupdate.common.license.HeartbeatFileSigning - Reading signature data from file /home/
kpit/.qnx/license/ownership.signature
2023-02-03 06:39:28 SEVERE com.qnx.swupdate.common.util.Try - Error: java.security.SignatureException: java.nio.file.
NoSuchFileException: /home/kpit/.qnx/license/ownership.signature
2023-02-03 06:39:28 WARNING com.qnx.swupdate.common.license.LicenseOwnership - Clearing license ownership data because
of errors
2023-02-03 06:39:29 FINE org.apache.http.client.protocol.RequestAddCookies - CookieSpec selected: default
2023-02-03 06:39:29 FINE org.apache.http.client.protocol.RequestAuthCache - Auth cache not set in the context
2023-02-03 06:39:29 FINE org.apache.http.impl.conn.PoolingHttpClientConnectionManager - Connection request: [route: {s}-
>https://www.qnx.com:443][total available: 0; route allocated: 0 of 5; total allocated: 0 of 10]
2023-02-03 06:39:29 FINE org.apache.http.impl.conn.PoolingHttpClientConnectionManager - Connection leased: [id: 0][route
: {s}->https://www.qnx.com:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 10]
2023-02-03 06:39:29 FINE org.apache.http.impl.execchain.MainClientExec - Opening connection...
