QNX SDP 7.1 Download failed
11/23/2020 8:47 PM
post121116
Hi ,
License of our company can download SDP7.1 and QOS 2.2
But QSC can't found package when import offline patchset Exp_SDP710_Hyp_Patchset_ADAS_ES6_20201117.qpkg.
Please see the following error message.
Cannot complete the install because one or more required items could not be found.
Software being installed: Exp_SDP710_Hyp_Patchset_ADAS_ES6_20201117.qpkg 1.0.0.0 (ADAS_Release.
Exp_SDP710_Hyp_Patchset_ADAS_ES6_20201117.qpkg 1.0.0.0)
Missing requirement for filter properties ~= $0: Exp_SDP710_Hyp_Patchset_ADAS_ES6_20201117.qpkg 1.0.0.0 (ADAS_Release.
Exp_SDP710_Hyp_Patchset_ADAS_ES6_20201117.qpkg 1.0.0.0) requires 'root-package; com.qnx.qnx710.target.hypervisor.vdev.
devel [0.0.2.00273T202009021448E,0.0.2.00273T202009021448E]' but it could not be found
Also we need the following specified version of tool to use Qualcomm QDrive 2.5 ES6.1.
By the ES6.1 release note, it seems not only qpkg but also some binaries should be gotten from QNX.
1. Download Base SA8195AU toolchain using QSC/patchset, please refer section 4.3.2.1
4.3.2.1 Import QNX Patchset
QPKG Name Exp_SDP710_Hyp_Patchset_ADAS_ES6_20201117.qpkg
QPKG Location <target-root>/apps/qnx_ap/qnx_bins/prebuilt_QNX710FIXME/patchset
NOTE : Few packages in qpkg requires access to specific foundry locations. Do contact your QNX
representative for access.
4.3.2.2 Additional files
Below files/packages should be fetched from QNX by mentioning respective version/build details and must be
replaced in <SDP710 Installation Absolute Path>
<SDP710 Installation Absolute Path>/host/linux/x86_64/usr/bin/secpolcompile
QNX_BUILDID=(GNU)eb5726ad58703d313b60a5809a66c654d9eeadf1
NAME=secpolcompile
DATE=2020-09-23EDT-14:23:55
<SDP710 Installation Absolute Path>/target/qnx7/aarch64le/bin/secpolpush
QNX_BUILDID=(GNU)de8f8d1c3ab8920e82e7b52a4e5d1042
NAME=secpolpush
DESCRIPTION=Utility for pushing a security policy to procnto
DATE=2020/09/17-08:53:36-EDT
STATE=Desktop
HOST=C02KF4UDFFT1
USER=rmaclean
<SDP710 Installation Absolute Path>/target/qnx7/aarch64le/usr/bin/secpolcompile
QNX_BUILDID=(GNU)19b6920b6f17ecbe542602167a05bf65
NAME=secpolcompile
DESCRIPTION=Utility for compiling security policy
DATE=2020/06/13-20:25:28-EDT
STATE=stable
HOST=sdp710-node1
USER=builder
VERSION=7.1.0
TAGID=710-SDP-472
PACKAGE=com.qnx.qnx710.target.security.secpol/0.0.2.00472T202006132107
<SDP710 Installation Absolute Path>/target/qnx7/aarch64le/lib/dll/pci/pci_server-buscfg-generic.so.2.3 already have
on SDP7.0, not sure if the same on SDP7.1
VERSION : pci_server-buscfg-generic.so.2.3 for SDP710
QNX_BUILDID=(GNU)d812dc9c1af137b40026ddd612aa9b39
NAME=pci_server-buscfg-generic.so
DESCRIPTION=PCI Server Generic Bus Configuration Module
DATE=2020/09/29-08:05:19-EDT
STATE=Desktop
HOST=mk3
USER=mkisel
Thank you.
