11/30/2018 1:53 PM
post119314
I'm trying to use hogs under QNX 7 and I'm not seeing any meaningful results.
The command I am using is
'hogs -%1 -s1'
to display any process using 1+% CPU and update at once a second.
The output I get from this command is attached. Essentially it shows 8 idle processes each consuming 12% of the CPU
(presumably because this is a quad core with hyper threading enabled so QNX sees 8 CPUs).
I've compiled and have Samba running. When I drag/drop a 100 Meg file from Windows to QNX it takes about 8-10 seconds
for the file copy to finish. During this entire time hogs doesn't report any other process using any CPU besides the 8
idle processes. However one of the idle processes then reports 4% CPU used leading me to believe 8% (or 2/3 of 1 core)
was busy doing the copy.
So my question is, does hogs work under QNX 7 and do I need to start any other process or include any special library or
instrumented kernel etc for it to report properly? I've used it without any problems in QNX 4 and QNX 6 so I'm baffled
as to why it's not reporting anything.
TIA,
Tim
